U65gt localization issue
    Hi
    I have a problem with the localization
    When i try to locate it in the parameter i have this message in the "Google location reporting" : "not available in China"
    Somebody know how I can fix that ?
    Thanks and sorry for my English
    It s OK
    After insert a sim the localisation is back
      when i remove the sims i have already the first message
      so it's doesn"t work whithout a sim !
      Do you have the same issue ?
