MX3 2.4G 3D Air Mouse & Wireless Keyboard with MIC and IR Learning Mode User Manual
Originally posted by BartAfterDark View PostIt has instructions for keys and voice. The voice function is listed as optional.
Both IR and voice functions work perfectly
KenBeelink S82 M8B MediaBox ... Android Kitkat 4.4.2 ... Vigica MX3 Air Mouse (Aerb, Sannysis) ... Logitech K400r
SIMPLE MEDIA CENTER USING GOOGLE DRIVE
LOGITECH K400r INSTRUCTIONS/RECOMMENDATIONS FOR ANDROID TV
ANDROID EXTERNAL KEYBOARD SHORTCUT KEYS [DOCUMENTATION]
NOVA LAUNCHER SET UP FOR INTERNET TV
DOCUMENTATION?
Originally posted by kenj66 View PostBart, could you be a little more helpful? We are trying to figure out the differences between these devices. I already re-posted the link to the MX3 user manual. Would you be willing to post the manual you have, provide a link or even post here the additional info from your user manual? Your help would be appreciated.
Ken
Originally posted by BartAfterDark View PostHai Yasi 2.4G Motion Sensing Air Mouse manual: http://imgur.com/aysv4y5Please consider making a Donation to freakTab
DOCUMENTATION?
Originally posted by kenj66 View PostHey, thanks Bart! My unit also has the Internet Explorer key instead of the MIC activation key. So, there are two different models of this remote. The user manual you posted was almost the same as the regular MX3 and I didn't notice (in the midst of broken English) any indication that you could program more than five keys.
KenI use the volume keys to turn the volume up and down on my tv and so on.
Originally posted by blinkone View PostI got mine from tinydeal its ment to have the mic but I cant figure out how to get it to work
http://www.tinydeal.com/mx3-24ghz-mi...-p-115077.htmlhttp://www.tinydeal.com/mx3-24ghz-mi...-p-116227.html
I would LOVE to be able to control the volume on my HDTV with this remote.
DOCUMENTATION?
Originally posted by BartAfterDark View PostAre you guys able to bind the colour keys at the bottom. They only seem to work, when the remote is in IR/TV functionWould have liked, if I could bind them to different tasks in Kodi.
If it helps any I have used the remote in Kodi. Press the Cursor Lock key and you should find the D-pad (directional pad) keys will work properly and the OK button will select the highlighted item. However, the eight keys above the Home key do not work for me in any context.
DOCUMENTATION?
No wonder we are confused. Look at this page on **** for a Vigica MX3M. Look at all the pictures on that page and you will see some with the MIC key and some with the E key
DOCUMENTATION?
Originally posted by kenj66 View PostI am puzzled at your question. On my unit the four colored keys at the bottom and the Power button in the upper-left are the ONLY keys that can learn IR codes. On my unit those five keys always send IR codes. All the other keys are sent to the TV box through the USB 2.4 GHz air mouse/keyboard dongle.
Ken
Originally posted by BartAfterDark View PostI don't mean IR function. Those work for all the keys I've tested. But I can't get the colour keys to register in kodi or on my windows PC. Guess they are only for IR functions.
DOCUMENTATION?
Originally posted by BartAfterDark View PostWell I canI use the volume keys to turn the volume up and down on my tv and so on.
DOCUMENTATION?
Originally posted by EvgeniX View PostPower and 4 colors buttons only.
Not true, i program all button i need from my tv remote. power,vol+/-, arrows to surf in tv menu, ok button, all numbers, mute, i take 'source' button and put to red button to switch from hdmi1(tv stick) to hdm2(pc) fastly. Test all working on rca, sony, samsung, lg and an old cheapest Emerson tv's.
First try the remote doesn't seem to enter in learning mode, i remove battery a puit put it back in all all work fine from there.
Very strengh signal event at 30 feet outdoor, i use to skip track in audio player.
Only one missing thing is a headphone jack or speaker to have a full functional voip sound input / output device. With my Nettalk app i could send voice but can't ear nothing through speaker( usb sound or stock hdmi output)
Obviously, you have a different model. It is unfortunate that the manufacturer and distributors fail to reveal the differences. Please see post #25.
DOCUMENTATION?
There are currently 2119 users online. 3 members and 2116 guests.
