Where is SportsDevil addon?
    Hello...iam trying to set up again my box....and i cant find SportsDevil at any repo.
    Also i try to install it manual and always failed.
    Do they have any issue ?
    I try to install it on Xbmc and Kodi too.
    plugin.video.SportsDevil.zip
    Try installing this one by going to system-addons-install from zip file and selecting the zip attached.
    EDIT. I meant to say. Try installing Mobdro and using sports in that instead. Far more streams and better quality.
    Firedown is a powerful download-app for your Android.
    To Infinity and Beyond.... XBMC
      Originally posted by Flumpster View Post
      [ATTACH]9171[/ATTACH]
      http://www.mobdro.com/
      thanx for ur replay Flumpster , but how i can install mobdro? You mean as an app from google play? Iam using Linux on my xbmc box.
        Ah sorry mate, 95 percent of posts on here are android related so I jumped to the wrong conclusion.
        Just try the zip I gave you then in Kodi or you could try Genymotion. https://www.genymotion.com
        Genymotion is an android emulator so you should be able to install mobdro into that. I have no experience with Genymotion but I have used Bluestacks (same sort of thing for windows) and everything works fine in there.
        Edit : Do you mean you are running linux on a TV BOX and you replaced android? If that is the case I doubt it is fast enough to be able to emulate android.
          Yes i have an mx 2 android box and i install on it the linux version. And i cant find the sportsDevil repository in any repo. So i install it manual from the file u gave me before thanx mate
            Sports devil is in flux due to being pulled from Git hub.
            Team UX
            http://www.ultimatexbmc.com/
            http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
              Sportsdevil can be found as digitele sports. Make a google search on that or check the following links
              Blogger ist ein Veröffentlichungs-Tool von Google, mit dem du ganz einfach deine Gedanken der Welt mitteilen kannst. Mit Blogger kannst du problemlos Texte, Fotos und Videos in deinem persönlichen Blog oder deinem Team-Blog veröffentlichen.
              Sent from my H30-U10 using Tapatalk
                nice information
                thanks all
                  removed
                    I'd think you'd be better off with a PS2... or a 60 gig PS3 that way you can get a PS3, play PS3 and PS2 games and Play Blu Ray DVDs.
                      You can install the original Repo from http://fusion.tvaddons.ag
                      Here are some guides
                      SportsDevil Repo
                      techdroidlife.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf techdroidlife.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
                      SportsDevil Via Ares Wizard
                      Once you install the wizard, open it, go to addons sections
                      OR the echo Wizard
                      open the wizard, go to popular addons, sportsdevil should be there
                      You can install other popular addons with the ares wizard and echo Wizard too
                      other sources
                      http://koditips.com pr seo-michael.uk for tutorials
                        Thanks for the guidance its really knowledgeable discussion. I'm also Kodi user and love to watch sports on Kodi, Recently I install sportsdevil on Kodi and no doubt it is best Kodi sports addon to watch live games. Thanks to ReviewsDir where guide about Sportsdevil
                          The newest version of Sportsdevil addon is v2019.05.20
                          For get new update & install guide for sportsdevil kodi addon: https://www.kodiboss.com/2018/01/how...ddon-repo.html
                            unable to download.. to many pop ups
                              What about an apk??
