Minix Neo X8 Plus (H) Custom XBMC Edition by Lifeforce
    I had a little free time, and I build a X8 Plus device firmware.
    - I have removed all the downloadable Google applications, and unnecessary programs.
    - CPU speed is set to be 1280-1920Mhz between
    - Removed all Launchers
    - XBMC programmed launcher (by Kodi 14.0 rc3)
    - XBMC tailored surface a bit and I adjusted to the compatible Neo X8 Plus.
    - OFF and Favourites buttons removed, thinned to RSS feeds.
    - Switch off function menu allowing immediate selection sub-menus.
    - Shutdown functions: OFF (this is feature never has not worked in the android), shutdown timer (Never has not worked in the Android), stop shutdown timer, and eventually restart the device.
    - Integrated into game controllers drivers (XBOX, PS, Joy) (not tested) (Thanks the developers))
    - I integrated root
    - Other tweaks
    WARNING!
    This is full firmware only Minix Neo X8 Plus (H)!
    SD card in flashable ZIP format
    Sorry bad English.
    Can be downloaded here:
    And control file:
    - I integrated root
    - Other tweaks
    WARNING!
    Sorry bad English.
    And control file:
    http://www.220volt.hu/temp/upload/pl...n.14.12.13.md5
    I'm sure people would love this well done
    Bugs are Sons of Glitches!
    JustMe
      Thank you Lifeforce!
      Good work!
        Will you do a new fw2 version for the non-Plus-devices too?
          did anyone try it??
            Originally posted by nutzu View Post
            did anyone try it??
            I'm using it. I installed Nova Launcher too.
            It works perfectly.
              It works perfectly.
              Hi New here.
              how do u install this is there any instructions or how to somewhere
              Danta
                1. Download the firmware, and extract it. Unzip the another zip file too.
                2. Copy all the three files to the root of an SD card formatted with FAT32:
                ___1: factory_update_param.aml (103 bytes),
                ___2: Neo.X8.Plus.XBMC.Edition.14.12.13.zip (319,434,404 bytes),
                ___3: recovery.img (8,285,804 bytes)
                3. Power off the X8-H Plus and unplug power.
                4. Insert the SD card into your Minix X8-H Plus device.
                5. Make sure you do not have an OTG USB cord plugged into the device.
                6. Plug power back in. Make sure it doesnt boot!
                7. Using a tooth pick go in and press and hold the Recovery button. You know you have pressed it if you feel the click.
                8. While holding the Recovery button down, press and release the Power button (and keep holding the reset button until 5 seconds).
                10. The ROM should auto install and reboot when done. If not and it boots into recovery use below processes. Your Done!
                It's an XBMC edition, only with XBMC launcher (Kodi).
                If you like the classic surface, install your favourite launcher from Play.
                  Thank you for the info
                  one more question after extract there is another zipfile do i leave like it is or extract that also
                  Thanks Danta
                    Thanks Danta
                    Copy to the root of the SDCard these files:
                    File name_________________________________Size
                    factory_update_param.aml___________________103
                    Neo.X8.Plus.XBMC.Edition.14.12.13.zip__319,434,404
                    recovery.img_________________________8,285,804
                      Ok got it thank you for your time
                      Danta
                        Yes.
                        Between the two holidays, I promise.
                          Download link is gone. Is there a new link?
                            Hello
                            I moved the firmwares
                              And what about the non-plus Edition?
