Hopefully someone can help me...
FYI, I have the model: CYX_809III_v5_2_20141105
Background: I bought this CX919 II, setup the device so that it displays in 1080p, install XBMC, and it only shows 720p. Do a bit of reading and find out that it's probably upscaling and there's a separate 1080p firmware, so of I go...
Problem: So I flash the stick with the steps below, everything seems to go okay, except when I plug the stick back into the tv, nothing happens... How do I get my device back?
1 ) Download Rockchip Batch Tool and extract
2 ) Put the USB cable into theOTG port of the CX919 II, hold the reset button and plug it into the pc.
3 ) Windows looks for driver, I send it to the correct location, it finds the drivers, no problem
4) Add SUPPORTLOWUSB=TRUE and FULLSPEEDUSB=TRUE to the config.ini file (otherwise it doesn't detect the device)
5 ) Start Rockchip Batch Tool v1.7. It finds the device and shows a green box
6) I select the 1080p firmware (which I got here)
7) Click on the restore button and wait patiently for the success message
8) Success message is displayed.
9) Unplug device, plug device into tv
10) Device has power, but tv tells me that there is no device connected.
So, where did I go wrong? And how can I fix the device?
I did manage to get some sign of life by using this firmware (I assume that this is the manufaturer), except all I see with this are just four flashing penguins in the top left corner.
Before it died, this is what the software info looked like..
