UG802 + 5.1 sound?
Originally posted by robgee65 View Postone way is that you amp must have a hdmi input
2nd way is you tv have a digital output
3rd you have a left and right out put from tv to amp
My tv has digital out to amp but same there
My tv has stereo out to amp but stereo is only 2 channel.
yes i get 5.1 on my ug802 using hdmi to my tv then optical out from tv with toslink to my amp it has when using oem video player seperated channels if the movie does and it sounds as good as playing the same movie on my blu ray player (ps3) it also displays dts when the file is encoded with that track also i had audio video sync issues with tv speakers but not on my digital amp!Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Originally posted by neodoom View Postyes i get 5.1 on my ug802 using hdmi to my tv then optical out from tv with toslink to my amp it has when using oem video player seperated channels if the movie does and it sounds as good as playing the same movie on my blu ray player (ps3) it also displays dts when the file is encoded with that track also i had audio video sync issues with tv speakers but not on my digital amp!
If you are using a player that uses hardware sound decoding you will get 2Ch.
If you use a player that uses software/pass through then you will get 5.1
None of these Android TV/sticks have 5.1 hardware decoding, but all can pass the raw bits through the HDMI cable you just have to use a player that allows it.
Once I get my iMito I will try out lots of options that I've been reading up on and let you all know what works, but I am thinking that something from here http://forum.xda-developers.com/show....php?t=1803871 might help.
Originally posted by markust View Post
Solution for this was Y-usb cable, where data part goes into usb hub, and power part goes into 5V usb adapter (which came with ug802). It is usable now, but haven't tried DTS and spdif, haven't got a cable...
Originally posted by absbrain View PostI have exactly this (blue) CMI 106 based usb sound card and I use it without SPDIF... It works only as stereo and it is a power hog. I have belkin USB hub (AC powered of course) and if I use this usb sound card, all my USB storages (USB stick, WD passport disk) periodically unmounts, and mounts, in the middle of the film
Then connected by optical cable from SPDIF to my AV-Receiver - an now the exciting moment.... : unfortunately only Stereo downmix again...
Perhaps must the ffmpeg-plugin for MX-player support/configured for 5.1 ? it looks like the ffmpeg-plugin is decoding the DTS-Signal and forwarding it as an analogue 2.0 signal to the audio HAL...
maybe this could help...
I´ve read in the linux-forums, that the asound.conf is to customise, when you will get a real 5.1 output.
#alsa can help
this is an example for a terratec-card
[1 #This asoundrc is for the CMI8738-MC6 only.
2 #It plays any sound sample through all 6 speakers.
3 #It also allows for the playback of 5.1 streams and 2.0 streams at the same time.
4
5 # 6 channel dmix:
6 pcm.dmix6 {
7 type dmix
8 ipc_key 1024
9 ipc_key_add_uid false
10 ipc_perm 0660
11 slave {
12 pcm "hw:0,1"
13 rate 48000
14 channels 6
15 period_time 0
16 period_size 1024
17 buffer_time 0
18 buffer_size 5120
19 }
20 }
21
22 # upmixing:
23 pcm.ch51dup {
24 type route
25 slave.pcm dmix6
26 slave.channels 6
27 ttable.0.0 1
28 ttable.1.1 1
29 ttable.0.2 1
30 ttable.1.3 1
31 ttable.0.4 0.5
32 ttable.1.4 0.5
33 ttable.0.5 0.5
34 ttable.1.5 0.5
35 }
36
37 pcm.duplex {
38 type asym
39 playback.pcm "ch51dup" # upmix first
40 capture.pcm "hw:0"
41 }
42
43 # change default device:
44 pcm.!default {
45 type softvol
46 slave.pcm "duplex"
47 control {
48 name "Software Master"
49 card 0
50 }
51 }
52
53 # for aoss
54 pcm.dsp "duplex"
55
56 pcm.dsp1 "duplex"
In principle should it be possible to configure the (blue) CMI Card or HDMI-passtrough on the same way... Sadly i havent enough experience to make it self...
Then is to configure audio_hw.c and audio_policy.conf like the following
There are currently 2350 users online. 1 members and 2349 guests.
