Prmanently connect a ntework drive in Android TVBox
    Hello,
    I would like to know if there is an easy way to permanently connect a network dive to a TVBox.
    Im currently using a RPi as XBMC player, i would like to know if any Android TVBOX using XBMC will be able to connect to those drives:
    A drive connected to a mikrotik router (SAMBA) and a kind of old "NAS" (LaCie network space).
    Or do you basically use the XBMC interface to mount all of this?
    Im asking this because on the many reviews people use to post on youtube, they usually browse the network by using a file explorer, but i would prefer to have that unit as any other "storage" to be able to add the contents to XBMC or QuickPic, for example.
    For testing Im using a tablet (Pipo p4), my TVBOX is shipped..., and over wifi im able to browse using an explorer (ES, RootExplorer, etc...) but not to mount it, so i cant explore the contents with other apps.
    If it is possible, will it be possible via Wifi or Wired only?
    I can mount it correctly with Cifs manager and with mount manager on tablet, but for example cant use it with the QuickPic.
    is anything missing???
    thanks
