Samsung Galaxy Tab 3
    I recently purchased a tab 3, which I love, but there is one issue I hope to get help with and that's battery drain
    With moderate use you can literally watch the % remaining go down. I was doing a TWRP backup and lost 5% in the short time it took to do the backup.
    I have done the normal saving tips, decreased screen brightness, stopped, froze or deleted battery draining programs etc.
    I'm hoping that folks on the forum can shed some light on this and help me resolve it.
    So have you tried any of the battery repair apps in Google Play?
    I used Advanced battery Calibrator & Battery Life Repair on a Moto X I purchased off ****.
    The repair app found a number of cells that it said needed help. The calibrator app hopefully helped.
    Did not harm to try. Maybe they would help you.
    Cube T9; Pipo M8 Pro (on life support); LG gPad
      a
      Thanks for taking the time to saythanks! It is much appreciated
      _____
      arooj
