newbie to android tv, how to start?
The pcb is
ZY_X6_V21 2014_09_20
and I'm nearly sure none of the wasser versions will work at this pcb...
Also google doesn't know ZY_X6_V21...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by omer.jacobi View Posthi i just got an cs918 hardware (i added a photo of it) and I want to make it perfect
what do you recommand, install wasser on it?
how do I now what wasser version do install?
and how do i backup the original software before?
thanks in advance
[ATTACH=CONFIG]9236[/ATTACH]
Originally posted by RISCy Dude View PostWhere did you get this box?
etopmarket
http://www.****.com/itm/371072339201?_trksid=p2060778.m2749.l2649&ssPageNa me=STRK%3AMEBIDX%3AIT
Ah, so you finally found the stock kitkat ROM for this thing? Did it have kitkat when you got it, or the more popular 4.2 image that comes standard on most of these?
Already flashed it and everything working like it should?
Cheers,
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
If the upload date has anything to do with when it was built then it should be fairly up to date. If you do decide that you want to try another ROM (I wouldn't necessarily recommend any from the firm because they are all from 2013) I hero help you learn how to change the system, but keep your kernel/boot image and anything else necessary.
It's possible that this fw isn't any newer than in the forum, just uploaded more recently. In that case I can help you update to the latest libraries for SPMC/KODI.
I would recommend SPMC, bc it's tailored to Rockchip.
Cheers,
There are currently 2446 users online. 0 members and 2446 guests.
