I quite like the spec and performance of Pipo p8 but had a bad experience with horrible build quality of the one I purchased before, which i returned and got refund. Now I want to try another seller and hope for a better built one, although I want to know the other owner's opinion on their P8 before buying.
Here is the list of issues I had :
- Very bad light leaking around 3 edges of the screen
- traces of glue around the screen where joining the body
- Twisting and creaking body which would impact the light leak as well
Mine was black version, I heard from a Chinese seller that black frame has issue , but white doesn't . can any one confirm?
