1080p youtube not working only 720p for Q7V Android 4.4.2 RK3188 Kernel 3.0.36+ yangfeihu@xintu #190 Fri Aug 8 2014
    Bought this heap of junk on amazon.es
    1080p YouTube not working only 720p
    And hdmi output is 720p, my tv is 1080p LG 42 inch.
    What to do?
    Also YOMVI Canal+ is not allowing to see videos...
    Can I spoof my tv box as Samsung Galaxy S3 ?
    Q7V Android 4.4.2 RK3188 Kernel 3.0.36+ yangfeihu@xintu #190 Fri Aug 8 2014 Smart MultiMedia Player
    Rk3188-eng 4.4.2 KOT49H eng.yangfeihu.20140808.100016 test-keys
    RK3188_R-BOX_ANDROID4.4.2-SDK
    Quad core rk3188 tv box Android 4.2.2
    Bluetooth built in
    Hardware Spec:
    Operation System:Android 4.4.4 Jelly bean
    Bluetooth:built in
    Chipset:RK3188 28nm Cortex-A9 Quad core
    GPU:Embedded 3D GPU Mali 400, High frequency 500Mhz, Support OpenGL ES 1.1/2.0 and OpenVG 1.1
    SDRAMDR3 2GB
    Nand Flash: 8GB Nand Flash
    : Storage Extension
    Support MicroSD(TF) ,Up to 32GB
    Network:2.4GHZ WiFi 802.11 b/g/n, LAN 10/100M Base-T
    Power SupplyC 5V/2A
    Interface:HDMI Out
    1xHDMI(A type Male),HDMI1.3 Full HD :1920x1080P
    USB Port:2XUSB Host
    Data Output:1xSPDIF
    :Card Readere:1X Micro SD card (TF card) reader
    AV Out:1x3.5mm Headphone Jack
    Network:1xRJ45 LAN Port
    Power Supply:1xDC Jack(2.1mm)
    Antenna:External WiFi antenna
    Audio Out:HDMI Data Output
    Video Decoder:MPEG-1, MPEG-2, MPEG-4,H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC 1920x1080P 60FPS
    Video Encoder:H.264,VP8,MVC(1080P) Resolution Full HD1080P@30fps H.264 Data Rate: Up to 60Mbps
    Image browser
    Support JPG, JPEG, BMP, GIF, PNG, JFIF etc photo format. Maximum resolution up to 8192x8192.
    Text-Reading Support TXT, LRC, PDF, Html, Htm, EPUB etc formats(Depends on APK install).
    Software Extension Support Google Play & APK install
    What to do?
    Bluetooth built in
    Hardware Spec:
    Bluetooth:built in
    SDRAMDR3 2GB
    : Storage Extension
    Power SupplyC 5V/2A
    Interface:HDMI Out
    USB Port:2XUSB Host
    Data Output:1xSPDIF
    Image browser
    I have this exact same box I cant even watch a film on xbmc that lag is terrible it not play HD videos at all even tried showbox app and they lag even with mxplayer, tried everything to get it working i cannot flash any roms to it as every one fails. would really like to get lewys rom working on it but i cant. my box is packed away waste of 60 quid at this time
      Same here basically. They are crap for sure.
      It's Kitkat AFAIK. We can get this working with one of leweys roms and his 1.23 kernel and videos will play well as this includes the stutter fix but not 1.24 or something along those lines. Thats all we have so far.
      Wifi and Bluetooth nor the LED on the power button work with this ROM. I have a working Kernel for these boxes found that even allows for 1.6ghz but the video is still borked. Sucks.
      Trying hard to do figure this out, really hard. Nothing solid yet....
        How did you manage to go into the FLASH mode?
        I can't get green color, only pink
          Shouldn't be using that program bud, it sucks. Use Android Tool 2.1 or RKAndroid Tool 1.37. Nothing else is needed for these boxes.
          Flash mode is simple. Either you plug the power in & hold the recovery button on the bottom of the device while plugging in a microUSB cable to the OTG port in the back.
          Or you boot into android make sure debugging is connected and click connect to pc under "USB" in settings. This is bring the device up on your PC as MSC/Mass Storage mode. Click switch in Android Tool. Done, flash mode.
          Easy.
          Check THIS out. Kernel for our XT-Q7/V-V10 TV Boxes. I get over 23200 in AnTuTu @ 1080p now with this box. Very happy with it. I stream 20gb 1080p MKV with ease now.
            Easy.
            Have you managed to get yours working?? how you do it any advice would be awesome!
              Easy.
              Just seen you linked in how to do it im gonna folow the steps now mate if this works you sir are a genius
