Mk902II LE (Linux Edition) Firmware?
@ scooter2014
Sorry, it would be really nice, if you would also use chars like
return
at your text (it would be much easyer to read)
The last post isn't a problem, but you also handle it this way at posts with text with 5 or more lines/rows...RK3288 Devices
- Overview BOX (LINK !)
Can someone please help me splitting the Rikomagic boot.img.
I have only been able to unpack the img using FW_Tools 5.23.18 but have no idea how to split to boot.img and kernel.img.
split_bootimg.pl gives me only "No Authorization/Keine Berechtigung" when i run it.
Thanks a lot!
Loewenzahn
EDIT: Sorry, had the wrong pemission for the script. Still fighting to split to 2 image filesLast edited by Loewenzahn; 02 June 2015, 23:12.
Boot and kernel in out put file when un packed. But why you un packing file for Linux I say ugoos works with network no split needed. You would have to un pack Linux file from ugoos to install resource file that all that need changed.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Thanks Scooter, i flashed now the UT3 image to the SD-Card and the network runs (very slow).
Still i want to see the original image from Rikomagic on this box (booting from SD-Card)
I splitted the boot.img and created a new separate kernel.img for tvbox from the extracted files.
Onto a 2nd SD-Card i flashed the kernel, resources and linux-rfs images but the box wont boot. The screen stays off. No penguins appear.
I have totally no clue where to start searching for a root-cause. I extracted and created the kernel for the 1st time, so maybe i forgot something?
I will start from scratch using the guide from Linuxium and will just load his example files onto the card to see whether the box boots up.
Originally posted by scooter2014 View PostYes if you have 16 gig box use duel boot the ut3 works with network not WiFi. I have running on mk902ii and best build if ugoos and or mac get acel running so I can use ubuntu it's good bye andriod lol... takes some time write to SD card with win image. Then insert SD card power on and it will boot to ubuntu. Wait till it loads and click on network top right select auto network it will start driver. Your on line.
Thanks.
Best regards
There are currently 3542 users online. 1 members and 3541 guests.
