Versus/CNM 9 Touchpad Problem
I think the page you are referring to with all the Chinese writing is some kind of diagnostics interface where you can test tablet functions like wifi, camera, sound etc.
If you can connect to the tablet with your pc whilst it is booting up (must be "android adb device") then you can use adb to wipe the data partition or delete the screen lock configuration file from your tablet. Check online how to do that.
Regards,
Regards,
Originally posted by tomtom196 View PostThanks for reply, I have tried to connect it to pc when booting up but it says problem installing tablet,tried trouble shooting still can't solve,
Sounds like your ADB drivers are not installed correctly. Search Google for ADB driver installation package or something similar. After installing, try reconnecting your tab (I presume windows failed to install any drivers for your tablet initially, otherwise you will need to uninstall the device first). After a successful install you should hopefully have adb access to your tab.
Can you tell me what your pc detects the tablet as when it tries to install it?
Originally posted by mr.crabs View PostSounds like your ADB drivers are not installed correctly. Search Google for ADB driver installation package or something similar. After installing, try reconnecting your tab (I presume windows failed to install any drivers for your tablet initially, otherwise you will need to uninstall the device first). After a successful install you should hopefully have adb access to your tab.
Can you tell me what your pc detects the tablet as when it tries to install it?Originally posted by tomtom196 View PostI bought this tablet to find it was locked out with pattern attempt i got it to recovery page i think but its all in Chinese please help,Ive tried the reset button on the back still cant get anywhere.thanks in advance
Craig
There are currently 2619 users online. 2 members and 2617 guests.
