mx2 clone box firmware?
    hi i bought a mx2 andriod box from fleabay and it crashed after first use, seller has not responded so thought ad try and get firmware for it. acemax firmware doesnt seem to work and have managed to get matricom 1.1.5 unbrick on it, but just loads of non-working addons on xbmc. Cant find the correct firmware on here and have been looking all over the net/forums. here is s pic from frak tabs that is exactly the same as my boxClick image for larger version
ID:	439819. and before the box crasched i went to settings and got g18ref from it.
    i think i have a cheap clone with the fact the heatsink is missing.
    is there any firmware that will work? just doesnt look like am getting a refund anytime soon.
    thanks in advance for any help
    now box just has red light on constantly and seems to be in a recovery mode loop, nothing on screen unless i insert sd then toothpick then power, then it just loops after back to reflashing after its done? cant get it working, any help would be appreciated
      I also hav the same problem as you, any solutions would be appreciated
        hi download this firmware from here and got it working, hope this helps!
