I've always had either a HTPC (Linux) or a proprietary/commercial media box (ie: Seagate) and this is my first Android based media box. I'm a Windows and Linux software developer so by nature it seemed like it would be fun and handy to try a Android based box for the low cost and good performance with seemingly the bulk of the flexibility I would have with a HTPC (Win, Linux or otherwise). I am not an Android power user though. I have a Android phone that is used for email, web, phone... basics.
So, I got this bad boy today and I'm starting to wonder if it is a good fit for what I need. Right off the bat it has quite a bit of overscan on TV. It is probably a 5 year old LCD, but the screen on my laptop and Seagate media box aren't clipped when connected to the HDMI, so it seems like the resolution needs changed or the screen resized to compensate for it.
I tried switching it to 720P, 1080i... no change as expected but worth a shot. I can't find any applicable info on how to adjust the resolution for the Beelink or even Android in general really that would correct this. Anyone have any advice on this?
Also, is there any primer out there that really gives a good overview of playing with these and configuring them. I'm not sure if it is beneficial to install any of the ROMs offered, which Apps are best to mount Window file shares or an NFS to the machine, which Root app is the best... all that good stuff.
Oh, the remote that comes with it is actually not bad if you had everything dialed in and just needed to click around to play a video or something, but it is hair pulling to actually use it like a phone, let alone a computer. =) Is there a clear winner for wireless mouse/keyboard/remote combos for a decent price for this type of application. I kind of like the idea of a touchpad mouse by a fly option would be ok. It has to have a keyboard. It would be great to be able to switch between modes.
I want to stay the course with thing and not go back to my aging little HTPC I built years back but after debugging all day long at work I don't know if I have it in me to battle the media player so I'm hoping someone can give me some insight to get me moving in the right direction here.
