AnTuTu Video Tester
Originally posted by frhdt007 View Post...No_spam should do that test again with 100% display .RK3288 Devices
- Overview BOX (LINK !)
Originally posted by frhdt007 View PostOverscan off??? Is it HDMI parameter ?RK3288 Devices
Interesting find
after fresh boot up -> everything is fine (no output at 2K hevc and maybe a little stutter at 4K hevc; maybe at 2-3 switches lines at screen)
next run with hidden nav-bar -> much more often lines at screen during switching
after fresh boot up with hidden nav bar -> the same as 'after fresh boot up' but without lines at screen during switching
next run -> the same
(BTW: CPU temperature during the test ~ 60-65°C, after the test ~ 45°C)
fresh boot up
- first running AnTuTu Benchmark X (v5.1)
(BTW: CPU temperature during the test at CPU operations ~ 75-80°C, at GPU operations ~ 60-65°C, after the test ~ 45°C)
- run AnTuTu Video Tester
Belief me, this was a scenario I had done before I wrote this whole scenario, because I got a score ~525 and many 'not passed' (and saw slomos and so on), BUT now I can't reproduce it ?????
Now everything is fine (also with shown nav-bar)...
I will try to force it after a longer cool-down (off)...
It's nearly the same as at the beginning where I got some freezes which I can't reproduce and the last days, everything is fine...???RK3288 Devices
AnTuTu Video Tester
Originally posted by no_spam_for_me View PostAt the TV at the format I can also select (not only 'auto, 16:9, 14:9, 4:3, ...') 'no overscan'...
I don't use NetFlix (no account)...
I also tested it at 'auto' and '16:9' and scaled the screen down to what ever % and tried it with and without nav-bar and also no problems...
At the second test at '16:9' I also hide and show the nav-bar again and again without any negative effect...
I connect the box direct to the TV and don't use any AVR at my test-environment:
I use this cheap cable (but nice handling) http://onlineshop.real.de/High-Speed.../0106390001002
and this TV (Grundig VLC 6110 C) http://manuals.grundig.com/uploads/t...632_en_TP6.pdfRK3288 Devices
Originally posted by trebor View PostI see why you don't have problems (Grundig)
Grundig can receive/interperate a signal using wet spaghetti as an input
Cheers
No, forget it, Grundig isn't any longer the good old Grundig, it's only the brand bought from a Turkish and USA company and so on...
But this TV has really nice picture-quality...RK3288 Devices
There are currently 1998 users online. 1 members and 1997 guests.
