First time poster, so please go easy on me.
Basically, I attempted to update the firmware for my "M8 S802 Box" with what I believed was the correct update. Everything seemed to go to plan and it rebooted, however when it booted up, for some reason it kept trying to bring a launcher window up on a loop and would not respond to anything other than allowing me to bring the mouse pointer up. So I downloaded a different firmware which should have taken me back to what it originally had. Because I could not get response the normal way, i found out the toothpick in the av port approach to boot to recovery. Once in recovery the box would not respond at remote at all. So I then tried one finally suggestion of putting all the files on a sd card and inserting that in the side of the box. Restarted the box and nothing at all happened, now it will not turn on at all, no blue light or anything. Could this be bricked? Any help would be appreciated.
Cheers,
Kev.
