Could anyone explain why I see only 1.5G RAM and 12G internal storage in Antutu with stock rom or Finless 1.1 beta 2, even though it's said 2G/16G in official description ? Thanks.
Wrong description 2G/16G ???
I think, but not sure, RAM because of 'shared memory' of the GPU...
NAND/eMMC because boot, kernel, system, recovery, backup (I don't know if all these also exists at Allwinner rom) uses space of the NAND/eMMC...RK3288 Devices
- Overview BOX (LINK !)
It's not wrong description, check your other android smartphone or tablet. they are all marked as 2G/8G or others, however, when you check with antutu, it tell only 1.3G RAM like this.
because the pre-installed software and OS need some RAM to run. it's normal, please don't worry.
EricLooking for developers
Originally posted by geekbuying View PostIt's not wrong description, check your other android smartphone or tablet. they are all marked as 2G/8G or others, however, when you check with antutu, it tell only 1.3G RAM like this.
Eric
I have many tablets : gateway , Acer, Asus ,Samsung but look at the picture from my Asus we see 16g, BUT system reserved around 5g, so total memory is 11g.
In Android tv devices I don't see that "system reserved ", and I got confused !
So on a 4g/32g telo ,we would see 3.?g/27g.
That's normal.
Thank you for answering my question !Last edited by frhdt007; 31 December 2014, 17:24.
There are currently 3528 users online. 1 members and 3527 guests.
