Firmware for mine CX919II / CYX809III
    Hey all,
    I just bought the CX919III from ****. It came to me not rooted, so i wanted to root the device. When I tried that it wont work, so i decided to put a rooted rom on the device. When i did that i got no screen anymore. I read much forums especially from Freaktab, but i couldnt find any solution. Can someone please help me with the right rom and how to flash it excactly.
    I found a ROM, but i get a bootloop. I see a black screen with Smart TV and then it restarts and keeps restarting.
    I got the CX919II. I opend to read whats inside. It is a CYX_809III V5_2 20141105.
    I hope for a solution. Many thanks in advance.
    Originally posted by zulfikar View Post
    Hey all,
    I ended up getting ripped off on **** by buying a cheap clone... it is described in this post the issues i had to even get the otg port to work... http://www.freaktab.com/showthread.p...ashing-rooting
    Anyway I used sam321s custom rom for it once i had soldered the pins together... so maybe his rom will work on yours. Take a look and see if the board is similar to those pics. Its rooted and no bloatware.
    give it a shot maybe it will work on yours. here is a link to his thread with a download link in there somewhere. I'm still running it after 3 months, no issues.
      Hey all,
      the only rom that will work(i have the same clone) is
      百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
      download will take some time all regards go to Veldkornet on this forum
        Hey,
        thanks for the reply, I am now downloading the rom to test it.
        Is there a way too root it after it? And what is the difference about this and the clone?
        Thanks !!
          http://www.****.nl/itm/171513451150?...84.m1497.l2649
          This is the one I have btw...
            Thanks!
            Damn... i spent two days trying to find a rom that works... now i at least have wifi workng. hope somebody can come up with a rom for this thing, but the stock 4.4.2 that im running now does the job... but the wifi does seem a bit slow
              Somebody rooted this device ??
                Yup me
                The stock 4.4.2 firmware seemed to be rooted from the getgo, at least thats what the Kingo root software told me when i started the root procedure... although i just re-rooted it and now it defenetly is rooted, i am running sixaxis just fine for my emulators
                  Mine device isnt rooted, how have you reroot it ?
                    I installed the ROM from http://pan.baidu.com/s/1qW1A12W, and then i followed the steps from these guys http://www.kingoapp.com/index.htm
                    You´ll need an extra usb cable to power the device, and you have use the one that came stock for the ogt port when connecting to a computer. And a piece of tape to hold the new usb power cable in place, since the stock plug is longer than standart usb connectors
                    Step 1:
                    You have to power up your device while plugged in to a tv(so you can se what the hell you are doing on the device) then tap on the build nr in "about device" a certain number of times to unlock develeper settings where you can select "usb debugging mode" (guide from the kingo app)
                    Step 2:
                    Dowload and install http://www.kingoapp.com/index.htm on your pc, then run the program. Then plug the usb that came with the device (it is made to fit because of the antennas) in to the free ogt usbport and in to the computer. now under settings->usb select "connect to pc"
                    Step 3: Do what the kingo software tells you to do. And presto!
                      Hey all,
                      I have this stick
                      Rom for this stick - https://yadi.sk/d/kw9BKrrFdZhWE
                      Working 100%
                        Originally posted by methead View Post
                        I have this stick
                        Working 100%
                        Is this a rooted rom ??
                          use Kingo Root for rooting
                            I have the CYX_809III_v5_2_20141105. Is any other rom worth to install besides the stock on it ?
                              I wouldn't try any others. That's how all the rest of us got non-booting/boot looping devices.
                              Cheers,
                              -SB
                              Currently using U-BOX R89 with mo123 v1.6.
                              Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
                              Pipo M9S -- CrewRKTab custom rooted 4.4.2
                              RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
                              ----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
