B4A Firmware problem
    Hi guys,
    I just bought a MEasy B4A box. Unfortunately there are some freezes while using Sky go for example.
    So I decided to flash another firmware. I would like to use the finless 1.9/2.0 but unfortunately the update (doesn´t matter with update option I use) doesn´t finish. It always says "signature verification failed - update abborted". I have already tried to download the firmware again to ensure that nothing went wrong with the download but it makes no difference :-(.
    Does anyone has an idea how to make it work?
    Thanks in advance!
    But you unpack the downloaded zip one time?
    RK3288 Devices
    - Overview BOX (LINK !)
