NEW - Minix X6 Stock ROM ??? 11/28 UNOFFICIAL?? in flashable ZIP format
    OK folks.... My X6 came with a ROM in it dated 11/28!
    I dumped it so I could keep it. Well you all get to also have access to it!
    I Emailed Ken at Minix asking why my box came with 11/28 but there was no download for it on the Minix forum. I am awaiting an answer. I will let you all know when I get an answer.
    In the mean time, I will give this to you so you can try it....
    The big thing? Which ROM do I use to make a custom Finless ROM?
    YOU GUYS tell me which is best! 11/14 or 11/28.
    Enjoy!
    __________________________________________________ _
    Understanding recovery and why it must be done from SDcard using my custom recovery!
    You will need a SDcard to use this package! Why?
    Because for the X6, Minix decided to sign ZIP update packages with new keys.
    The recovery is not using standard Google keys!
    I do not have those keys yet but I have asked Minix for them. We shall see.
    In the mean time, I had to modify their recovery.img so it worked on standard Google keys.
    This is the only way to use my ZIP packages! Now the keys match and it works.
    BUT... what does this mean? It means you MUST USE A SDcard! Why you ask?
    AMLogic device on boot to recovery (using reset button or a reboot app) first looks on SDcard for a recovery.img
    If it doesn't find one on SDcard, then it uses the recovery in NAND memory.
    Well the one in NAND memory I cannot use because it uses different keys...
    So you MUST use my modified recovery booting from SDcard.
    Make sense?
    Good.... On with the show.....
    DO NOT just put this download on the SDcard! Unzip the download and see the readme instructions!
    Here are the download links.
    ROM -> Minix X6 - UNOFFICIAL 11/28 Stock ROM in ZIP format - (420 megs)
    Enjoy,
    Maybe save a bit of energy for a few days mate
    The new firmware is only a few days away which should solve the 100% CPU bug etc.
    I would guess this firmware would have the bugfixes/additions from the stock 002 X8 firmware & the upcoming one will finish off with the remaining 002a bugfixes/additions
