For the story I have bought a r89 box (for information it is the best firmware and hardware rk3288 box!!) But like a fool I used the wrong charger and then doesn't work anymore... so I find the TV01II in geekbuying for very low price (60 euros )and I bought it! I don't know if it is just my box but I tried all the firmware (original one, cloudnetgo,custom from shumari...) and all those (more or less) are laggy, the cursor goes slow very often, when I listen to music get jerky often too... it is very boring and those lags play with my head . It have been two days that I flag, reset this box... is that hardware or software? Again thanks!!
TV01II lag problem with all roms
Hi everyone ! First I am French and I am 16 so don't be too too mean about my English
For the story I have bought a r89 box (for information it is the best firmware and hardware rk3288 box!!) But like a fool I used the wrong charger and then doesn't work anymore... so I find the TV01II in geekbuying for very low price (60 euros )and I bought it! I don't know if it is just my box but I tried all the firmware (original one, cloudnetgo,custom from shumari...) and all those (more or less) are laggy, the cursor goes slow very often, when I listen to music get jerky often too... it is very boring and those lags play with my head . It have been two days that I flag, reset this box... is that hardware or software? Again thanks!! -
Use some usb extender or cable to move the mouse dongleaway from the box.Everything is possible if we work together!
Tray:
1. Reset the device to factory settings
2. Use usb extender
3. Use difreant HDMI cable
4. Tray difreant power suplay
5. Tray on difreant TV
If this dont help you need to search for firmware for your device wich hopfuly resolve your issue.Everything is possible if we work together!
2. Use usb extender
What I can't explain is why this problem happens more on one rom than an other agsince thanks!
Originally posted by wenlez View PostMy TV01II unit works pretty well. Doesn't seem to lag.
Originally posted by GFG99 View PostProblem solve !!! Actually it was the HDMI cable guilty . It was the one that is given with the box, very poor quality (thin...). Now that i use my good HDMI cable all works fine !! So no problem. Thanks Lewi20041!!!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi guys I am having a similar problem my audio stutters and my curser lags I have tried both roms avail for tv01 ricomagic rom and a few others but I get the same problem I have tried a few hdmi leads and even the av cable.
I also keep having wifi direct popping up on my wifi scans and I cannot find a way to disable it? I have a feeling its down to the wifi radio and I have tried both 2.4 and 5g but the problem persists I am going to try get some mp3s on device and sdcard and see if it still does it with wifi disabled !
Its kinda like something is randomly maxing out resources in the background spiking the cpu mem or mmc but I cannot work it out.
Also on a side note does anyone have an android img that will run from sdcard even just the stock rom for this box so I can try that as I do not have access to a linux box.
Edit:Well just tried with internal flash sdcard in card reader and usb readers and mem stick looks like theres a prob with reading and writing to internal emmc which is causing lag I just need to test now booting from sdcard.
Does anyone know of a script or program that can make rom to sdcard like Linuxiums linux scripts but on windows?Last edited by LostInKontrol; 01-04-2015, 14:51.
to boot the box to Linux?
But not able to use this
at the Linux at the box (of cause with a SD-Card-reader for USB to generate the Android SD)?
At PC you should use https://www.virtualbox.org/
=> for windows host https://www.virtualbox.org/wiki/Downloads
and install a Linux
=> VIb) Linux at a Virtual Machine http://www.freaktab.com/showthread.p...l=1#post157646
(maybe 32bit to avoid the "64bit-problems")...
And no, the scripts are only working at LinuxRK3288 Devices
- Overview BOX (LINK !)
Thank you No Spam yes I can boot linux but no wifi sound etc I have installed ubuntu and the scripts work fine but not on my box it goes straight to recovery and says cannot mount /mnt/externalsd or something similar I will keep on trying as I just want to know if it will still lag with android running from sd but not having much luck getting box to boot.
Update: I managed to flash Wassers rom via the scripts and it seems to work great however no wifi the first boot had a consistant lag stutter on audio from mp3 but after a reboot it was gone ! I only had a quick go and as I didnt have many apps installed I will try again later see if it still lags out.
Does anyone know how to insmod the 6630 modules to get wifi working instead of trying to flash different kernel img etc.Last edited by LostInKontrol; 01-05-2015, 13:32.
Lag - Buffering problem with eHomeMediaCenter
Dear all,
Originally I have owned a Tronsmart A928 device, which was pretty fine, but recently decided to invest for one more device, now with the improved architecture and functions - so an RK3288 device. TV01II was for a nice price, so I bought it :-)
Now my problems start; I have used eHomeMC as basic player, and I expected to have improved playability. Unfortunately it is not, even worst.
File opening is really slow, then buffering do stops the movies almost every second.
Tried with stock roms (original, and the updated from december)
Do you have same experience?
Secondary,
I have some not to phancy games (like Rayman's Jungle run for my kids) and it seems to be laggy as well.
Shall I try HDMI cable to change (for what reason?)
After some players tried; KODI(xbmc) works better...
One more thing, with the A928 the audio settings were more sophisticated. I was able to use the remote controllers headphone connector and it's mic for chat. Now with the TV01II it is gone.
I have one more remote controller for play double touch games, a Tronsmart Tm02 device, but it is not recognised at all.
Do you have some proposals what to do?
There are currently 1528 users online. 11 members and 1517 guests.
