mk808 too slow for playing flac in kodi/xbmc/spmc?
    Hi, though 720p moviez seem to play just fine, my mk808 has problems playing flac files. There's round about 1 little lag every minute - and by "lag" I mean that the sound just stops. Has anyone else the same problem?
    - mk808
    - prahjister rom 1.1
    - 1080p kernel
    - kodi 14.0rc (current nightlies) / spmc 13.3.x
    - flac files are on a samba share that I've added in kodi/spmc
    The audio output settings seem to have no effect. I experienced the lags with all 3 settings:
    - optimized
    - best
    - fixed 48kHz
    Also deactivating some features (like normalizing volume by album/track metadata) had no effect.
    Meanwhile I even wrote a script to renice some processes...
    - kodi -3
    - mediaserver +5
    - surfaceflinger +5
    ...but still no luck. The lags remain.
    Any ideas?
    edit: here's my renice script - for backup reasons
    Code:
    #!/system/bin/sh
    # busybox is required for pidof
    while true
    do
        kodi=`pidof org.xbmc.kodi`
        if [ $kodi ]; then
            renice -3 $kodi
            ionice $kodi be 0
            prg=`pidof surfaceflinger`
            if [ $prg ]; then
                renice 5 $prg
            fi
            prg=`pidof mediaserver`
            if [ $prg ]; then
                renice 5 $prg
            fi
        fi
        sleep 10
    done
    exit 0
    Maybe it is a network issue. Try to play a flac file from the internal storage and see if the problem persists.
      Maybe you're right - there's no lag when playing the same flac file from mk808's internal storage.
      However, it's not like my network's bandwidth is too small, because when playing the flac file from the samba share it doesn't make a difference whether I "flood" my wifi at the same time with other things or not. I can even copy the file with kodi's file manager (samba share to internal storage) while playing it simultaneously from the samba share.
      Adding some tweak parameters to the smb.conf on the server...
      Code:
          socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
      ...doesn't make any difference.
      Meanwhile I also share the flac files via NFS v3 (the server doesn't support NFS v4 unfortunately) and it seems to be better than the samba shares. But occasionally there's still a lag.
        Okay. So it seems that the problem is not the network connection itself but some kind of buffering/caching issue. I never tried Helix on MK808B, but i also have buffering promlems in SPMC. I recommend you try Beyond XBMC 3.4. That is the XBMC version i had the best results with.
        You can get it here: https://www.androidfilehost.com/?fid=23329332407583710
          Also make sure that your server streams okay by streaming to another device (mobile phone or PC).
