[HowTo?] Bring HPH_RK3288_ROM_v_1.2 to a ENYBOX or ENY-CLONE
    Hey guys, I dont want to spam the thread of mo123 anymore and also I am little bit confused about the widespread information.
    So I own a ENY-BOX Clone:
    Chipset: RK3288
    PCB board: ENY-Q8P-V10
    Seller/Shop: ShenZhen HiDeer Technology Co.,Ltd
    Label: OTT TV BOX RK3288 Quad Core Model: EKB328
    More Info and photos of pcb here.
    This should be a present tonight
    Perhaps we can bring mo123's rom to run before, else I give it the person with this stock-rom tonight (a little xmas present).
    So what happens:
    Oldouse and I try to flash HPH_RK3288_ROM_v_1.2 to this device (ENY-Q8P-V10).
    Originally posted by oldhouse View Post
    Would this rom work with enybox clone ekb328?
    Yes, if you use your boot, resource & kernel.img.
    Can extract it with the flash tool.
    You have to download the stock ROM of your device.
    Then download my ROM with flash tool.
    Then use the 2nd or last tab of the flash tool to 'unpack' the update.img(stock ROM).
    Then copy the unpacked boot,resource & kernel into my ROM's rockdev/Image folder, replacing the 3 image files already there.
    Then flash normally by 'lowerformat' and 'run' on the first tab of the flash tool.
    I have created upgrade.img replacing those 3 files, but then I had to flash device in mask mode cause it got stuck at "testing" during flash operations
    It would be nice to mix your rom with this firmware http://pan.baidu.com/s/1pJqgM4V but android tool can't extract it.
    Try flashing the images separately, also use misc.img from your stock ROM.
    Will not mix buggy firmware, why they name firmware update and not device name?
    99% of people will not even know about this firmware and flash it to the wrong device.
    So I try the same and get also into kind of brick and have to do maskrom mode:
    Originally posted by DuHaudegenDu View Post
    Oh oh... Seems that something went wrong on my ENYBOX EKB328 clone :-(
    Like oldhouse has one...
    This is my parameter from stock:
    Code:
    FIRMWARE_VER:4.4.2
    MACHINE_MODEL:rk30sdk
    MACHINE_ID:007
    MANUFACTURER:RK30SDK
    MAGIC: 0x5041524B
    ATAG: 0x60000800
    MACHINE: 3066
    CHECK_MASK: 0x80
    PWR_HLD: 0,0,A,0,1
    #KERNEL_IMG: 0x62008000
    #FDT_NAME: rk-kernel.dtb
    #RECOVER_KEY: 1,1,0,20,0
    CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board  androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init  initrd=0x62000000,0x00800000  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00400000@0x00214000(userdata),0x00020000@0x00614000(radical_update),-@0x00634000(user)
    I load your HPH RK3288 v1.2 2014/11/17 plus the 2GB Parameter file for 8GB Box
    Then I try to flash it. Like you decribet here:
    http://www.freaktab.com/showthread.php?18706-HPH-RK3288-ROM-v1-2-by-mo123-(20141117)&p=252943&viewfull=1#post252943
    After 30minutes nothing happens, just "Testing device" was at status field.
    So I log off and log in.
    Every flasher now stop at: "Testing device"
    Also the RKBatchTool.exe when I try to flash the stock-rom. :-(
    WHAT CAN I DO?
    WHAT WENT WRONG!
    Here the log:
    Greetings by DuHaudegenDu
    THX, it worked after some pm's with oldhouse.
    So it is the black arrow you should count to 7-8 pin (only fpr ENY EBK328 clone device):
    -connect only usb
    -start Rockchip Batch Tool v1.7 as admin
    -PIN the 7 & 8 connectors
    -Then when you did this, connect the power cable
    -Rockchip Batch Tool v1.7 should show you instead of an green device label a blue device label
    -If is is blue you can simply flash yur stock rom again
    To mo123:
    We know that this device is not best (you show us here) but did you think you can told us how we can run your rom on our device? What did we wrong?
    Stock rom is this here. (source: ENY2005) Or this older one.
    Try to flash the whole ROM again, but use this misc.img file instead.
    Then try flashing your stock kernel,resource.img back for wifi and compatibility.
    If this doesn't work, the manufacturer of your device might be causing some problems, they locked their firmware on their AMLogic boxes so you can't use it on other boxes or clones and also not other firmware on their boxes. Maybe the same is happening now.
    Okay, now I a little bit confused.
    1.
    I load my stock rom again.
    2.
    I load New: HPH RK3288 v1.2 2014/11/17 Here or Here
    3.
    Start HPH_RK3288_ROM_v_1.2\AndroidTool_Release_v2.3\Andr oidTool.exe
    ^Works fine!^
    4.
    Put a thin pin into the recovery hole and press power some seconds to bring my box into recovery mode to be able to flash a rom ort parts of it.
    5.
    So I copy boot, resource and kernel image from step 3 extracted process:
    HPH_RK3288_ROM_v_1.2\AndroidTool_Release_v2.3\Outp ut\Android\Image
    to (replace it!)
    HPH_RK3288_ROM_v_1.2\rockdev\Image
    6.
    So I download http://www.mediafire.com/download/5j...c_wipe_all.img , renamed it to "misc.img" and copy&replace it here:
    7.
    And what now? Should I flash the hole rom from mo123 an then the other parts and the special "misc"???
    I TRY THIS NOW and do MASKROM IF FAIL:
    Instructions
    Connect OTG cable to box and PC.
    Hold paperclip/toothpick into reset hole while connecting the power to box.
    It should now connect. If not reinstall the drivers and try again.
    1. Unzip with 7z (I did allready)
    2. Use the first tab of AndroidTool v2.3 to select the Images to flash from the ROM.
    (Already set-up by default)
    Default is 4GB Userdata, but can be replaced with updated above parameter files.
    3. Click 'LowerFormat'
    4. Click 'Run' to flash the ROM
    5. Wait 5 minutes
    6. Unplug device from PC.
    7. Connect to display.
    What happens:
    After click "LowerFormat":
    After click "Run":
    SO I WAIT NOW 5 MINUTES....
    EDIT: WAIT NOW 6 MINUTES... I THINK THE SAME ISSUE LIKE WITH THE OLD MISC.IMG :-( HOW SHOULD I CLOSE THE TOOL??? OhOh
    Afrer plug of usb cable from otg port, I can close AndroidTool 2.3:
    No I have to do Maskrom. :-(
    Try to flash the custom files in muskrom-mode to bypass the test-phase, but got no success:
    WAIT 6 MINUTES AND DISCONNECT USB OTG:
    Gruß DuHaudegenDu
    Chipset: RK3288 & AP6330
    Bootloader seems t.b. locked.
    But Android 5 (wasser rc4) runs on it
    Try to flash wasser v2.0.3 ROM from Beelink forum.
    You use the 2nd tab of flash tool and just say upgrade after selecting firmware with firmware.
      Okay, i load this firmware:
      Start your AndroidTool.exe from your rom-package.
      Click on the secend tab called "Upgrade Firmware" and press on "Firmware", load the firmware file out of the wasser-2.0.3-beelink-r89-rk3288.zip, and press "Upgrade".
      Right?
        Right?
        Yes try that, the extracted file.
        If not working try erase flash and then upgrade again.
          Did you mean no flash working or no start working?
          EDIT: SUCCESS:
            After you flash and it gives you an error as previously or flashing fails, then try eraseflash and flash/upgrade again but only if upgrade doesn't work.
              Upgrade worked nice:
              But of course don't start.
                If this firmware also don't start then your device is locked.
                Would try to get rid of it and buy new device.
                Nagrace has 2GB RAM/16GB ROM device with airmouse and DHL delivery for $149 on aliexpress but only 4K @ 30fps because it also has HDMI-IN. Other device without HDMI can have 4K @ 60fps.
                Depends on what you want.
                  I only flashed WASSER ROM like you told me, I DO NOT FLASHED THIS ROM with my boot,resource & kernel img files from my stock-rom.
                  And yes with only flashed WASSER ROM it do not start.
                    Unpack wasser ROM and replace his kernel,resource.img with your stock ROM and flash individual parts from first tab of flash tool and see if it works.
                    Will probably not work.
                      Sorry for 1000 questions, but wich parameterfile should I use?
                      My stock rom has:
                      Code:
                      FIRMWARE_VER:4.4.2
                      MACHINE_ID:007
                      MAGIC: 0x5041524B
                      ATAG: 0x60000800
                      MACHINE: 3066
                      CHECK_MASK: 0x80
                      PWR_HLD: 0,0,A,0,1
                      # in section; per section 512(0x200) bytes
                      #CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00002000@0x00192000(metadata),0x00020000@0x00394000(radical_update),-@0x003B4000(userdata)
                      Should I use your default?
                      EDIT:
                      When I use your default parameterfile and replace boot.img , kernel.img and resources.img with that from wasser-rom and copy, this happens again :-(
                        Out of ideas.
                        maybe someone with same device can also try solutions.
                          Any news about porting other roms on this device?
                            Yah this box was a big waste of money... i tried flashing other roms but I lose WiFi and Remote
                              Can somebody explain me, why it is not possible to flash another Rom.
                              What did we need from the company?
                              Greetings by DHD
