M8 nothing showing
    M8 nothing showing
    I have an M8 box which was running Finless 1.7 for a while now and all of a sudden I get no signal on my TV. I tried a different HDMI cable and a different TV but still have the same issue. The blue light is on.
    It won't go into recovery with toothpick method and I have also tried loading a new ROM but nothing. Any ideas? Can I boot into recovery from SD card?
    I had the same problem with mine. No idea what happened, nobody here could help, so I decided to buy MX box to replace it as it was cheap at Geekbuying.
    So after the box was left alone for about 3 weeks I decided to open it up take a look inside, seeing as I had nothing better to do. Everything looked okay, so I put it back together and it started working again, except for the IR remote stopped working.
    Strange huh?
    So only advice I can give is maybe leave it unplugged for a day or two and try it again.
      It's been like that for over two weeks now. Maybe i will open it up and check if everything looks OK and try again.
        if can't recovery from SD card, you can try fix with PROBOX2-EX-upgrade-tool methode, this tool can flash your M8 box from PC via male to male USB cable
