ROM UG802 and MK808 for (MK802 Rikomagic III) tested
    Hi all, I buy a (MK802 Rikomagic III) 3 days ago, and I have successfully installed the ROM 1.4a Finless "UG802" (which works fine).
    Then I installed the ROM Finless 1.5 "MK808", everything is installed, but I can not use the wifi and the RJ45 it works very poorly done planted key.
    I found that with the ROM Finless 1.5 "MK808" on youtube, the video stutters in 1080p.
    Finless 1.4a ROM with "UG802", everything works fine (1080p video).
    So I'll try to get back to the ROM 1.4a Finless "UG802" which would be more compatible for (MK802 Rikomagic III), here.
    I managed to broke rikomagic MK802 III
    I read in the website of "freaktab" method flashing for the UG802 is it to work, I went back to the same original ROM that rikomagic MK802 III
    I installed the ROM "2dark4u", it works very well, fast, wifi ok, RJ45'm planted the key (I tested the fix for RJ45 but still the same problem).
    Finless thank you for your ROM and 2dark4u.
    I'm french (belgium), excuse me for the translation google.
    Hmm if the ug802 rom works well on the MK802 III, than the Android 4.1 rom from the MK802 III should also work on the ug802? Does someone tested it already?
    Edit: I hope you saved the original MK802 III Firmware and can share it?!
      Can we get the MK802-3 ROM please?
        can you please share the original rikomagic mk802 III rom ?
          Agree. We need this ROM, because mine UG007 will arrive after 10 days or even later.
            If UG802 ROM works on MK802 III that mean MK802 III ROM will works on UG802.
            We are saved
              We are saved
              Only if we can get the dang ROM!
                We cant get this rom today because Rikomagic do not release them. It is only in device. We must wait
