Well This is what I did over christmas and Gave myself a present this is a two part post. I do alot
of rework reballing phone programming etc.. Well I give to you my latest creation! Its Alive Muahahahah!
The simple fact is i am tired of running back and fourth dealing with stupid little radioshack soldering irons and solder suckers and using a heat gun on some boards... Well This Christmas I went a bit Nuts and after some thinking and a little bit of planning and some Greenbacks and of course my girlfriend looking at my as if i was nuts cause after my 4th pot of coffee and several Packs of Winston along with a 40 I came up with this. Extreme Maybe Insane Surely But hell its everything thing I need in one spot To do my jtags My android tv sticks along with phones and not to mention other items of intrest like fta equipment etc... So I thought I would share this with you and you all will probably get a laugh outta my Italian Red Neck Ass Modifications.. It started off life as a Kobalt workbench from lowes and Well er um a little work and I give to you
The Mondomatic 9000 Version 2.0 Rework Reflow/Programming Bomb Building (Lol) Station
The Guts,
1 Amd am2 platform Motherboard with an atholon over clocked to 3.20 ghz with 8 gigs of ram a 2 terabyte hard disk Nvidia gt 430 graphics card
a 10 port 12 volt 2 amp Usb Hub a 3 port autoswitching Hdmi with Ir, a 24 inch Vizio monitor twin 200X usb electronic Microscopes, 1 attached to a
magnification lamp to give me variable pitch and adjustment and one for close up on board soldering 2.0 speakers to listen to tunes while i work a 650 watt power supply to power the crazy thing. I then went and mounted my Yihua 968 db+ digital Hot air Soldering Iron Station to it Also Cut in a dvd drive up in the shelf "I still have to trim around it" then added a 1/3rd Hp Compressor to Run my die grinder air dremel tools etc I then Put a copy of windows 7 64 on it and Also Run Virtual Box so I have Ubuntu on it as well for my c programs and compiling. The Draws are filled with my radio Shack electronic Xbox Terrorist Kit and other assorted goodies. The overhead was Built with 1 inch Pvc Pipe some Track Lighting and an overhead 2.0 hd camera with built in mic. As for Security I added a feature
Thanks For Looking
Tony
Aka Darkhorseman45
Aka Mondoman22
