[RELEASE] MK802 III firmware 31 Oct 2012
    Hi.
    I wrote to Rikomagic and I get original firmware from 31 Oct 2012 for MK802 III
    It should works on UG802 (this same RK3066 chip).
    Mr. Finless, Mr. 2dark4u could you do your magic, please
    Download
    or
    Mirrors
    GOOD !
    Originally posted by CowPL View Post
    Hi.
    It should works on UG802 (this same chip).
    Mr. Finless, could you do your magic, please
    Download
    Mirrors
    Wow ! Downloading from Ukrainian service is so fast
    trying to flash...
      how to make it a valid update package for ug802? it gets recognized as one, but isnt allowed to update...
        trying to flash...
        share the link so we can work on it.
        i have also asked it to other provider i hope this works ok.
          Download:
          Mirrorsss:
          Securely upload your files, media and documents to more than 30 cloud storage providers simultaneosuly. Remote Upload files to Google Drive and many other hosts.
          source: http://www.rikomagic.co.uk/forum/vie...php?f=9&t=2486
            I did try install it directly into ug802 and the installer does not allows you.
            so probably un packing and re packing it will be the solution.
              Hi.
              Download
              or
              Mirrors
              HI ,guys, I have got the ugoos UG007 sample, and do some test, here is some reviews:
              At present,the mini PC have gone into the people’s heart deeply.People are conquered by their small and easy carrying.Now I show a TV stick to you .Tts name is UG 007.It’s volume is as small as an usb disk.This kind of TV stick have a black one and white one .
              So i think now i can ask them to give me the firmware for the JB and then we can try to flash to the UG802.
              and for the audio sync problem on UG007, i did a test according to this instruction:
              and here is the test video:
              Seems they solve the audio sync problem in the new JB rom?
              Anyone, once i get the rom,i will post back.
              thanks for you guys.
              Looking for developers
                Cool.... I will look at this today and see how it works on the ug802.
                you will not be able to update.img to ug802. You must use the flash tool RKBatchtool to flash the update.img. This is because update.img and update script do not match model.
                  so just rename update.zip to update.img and then use rkbatchtool on it?
                    I am still downloading it so let me look at what it is once it is done.
                    If it is a update.zip chances are you unzip it and you will have a update.img.
                    Update.zip is not a Rockchip thing like other devices. It looks for update.img not .zip.
                    I doubt they would release a update.zip so try unzipping it.
                    FYI the download is a .rar not a zip!!!
                      the file is a RAR
                      then when you un pack you get the update.zip and if you unpack that you get the standard patch rom. like the ones used with WCM.
                        WCM?
                        You mean ClockWork Mod?
                        No one has clockwork without special ROM. So if it is update.img, you either flash it with RKBatch Tool or put it on SDcard and RKupdater will install it.
                          WCM?
                          what i did try to mean is that is a standard update.zip
                          this are the files output.
                          https://skydrive.live.com/redir?resid=7D541625E0427612!2175
                            build.prop
                            # begin build properties
                            # autogenerated by buildinfo.sh
                            ro.build.id=JRO03H
                            ro.build.display.id=MK802III-eng 4.1.1 JRO03H eng.ant.20121031.140144 test-keys
                            ro.build.version.incremental=eng.ant.20121031.1401 44
                            ro.build.version.sdk=16
                            ro.build.version.codename=REL
                            ro.build.version.release=4.1.1
                            ro.build.date=2012年 10月 31日 星期三 14:02:16 CST
                            ro.build.date.utc=1351663336
                            ro.build.type=eng
                            ro.build.user=ant
                            ro.build.host=test-desktop
                            ro.build.tags=test-keys
                            ro.product.model=Rikomagic MK802III
                            ro.product.brand=rk30sdk
                            ro.product.name=rk30sdk
                            ro.product.device=rk30sdk
                            ro.product.board=rk30sdk
                            ro.product.cpu.abi=armeabi-v7a
                            ro.product.cpu.abi2=armeabi
                            ro.product.manufacturer=rockchip
                            ro.product.locale.language=en
                            ro.product.locale.region=US
                            ro.wifi.channels=
                            ro.board.platform=rk30xx
                            # ro.build.product is obsolete; use ro.product.device
                            ro.build.product=rk30sdk
                            # Do not try to parse ro.build.description or .fingerprint
                            ro.build.description=rk30sdk-eng 4.1.1 JRO03H eng.ant.20121031.140144 test-keys
                            ro.build.fingerprint=rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/eng.ant.20121031.140144:eng/test-keys
                            ro.build.characteristics=tablet
                            # end build properties
                            # system.prop
                            #rild.libpath=/system/lib/libreference-ril.so
                            #rild.libargs=-d /dev/ttyUSB2
                            # ADDITIONAL_BUILD_PROPERTIES
                            ro.com.android.dateformat=MM-dd-yyyy
                            ro.config.ringtone=Ring_Synth_04.ogg
                            ro.config.notification_sound=pixiedust.ogg
                            ro.carrier=unknown
                            ro.config.alarm_alert=Alarm_Classic.ogg
                            dalvik.vm.heapstartsize=8m
                            dalvik.vm.heapgrowthlimit=80m
                            dalvik.vm.heapsize=384m
                            ro.config.facelock=enable_facelock
                            persist.facelock.detect_cutoff=5000
                            persist.facelock.recog_cutoff=5000
                            persist.sys.usb.config=mass_storage
                            persist.sys.strictmode.visual=false
                            dalvik.vm.jniopts=warnonly
                            ro.rksdk.version=MK802III_ANDROID4.1.1-SDK-v1.00.1015
                            sys.hwc.compose_policy=6
                            ro.sf.fakerotation=false
                            ro.sf.hwrotation=0
                            ro.rk.MassStorage=false
                            ro.dlna.devicename=Rikomagic
                            wifi.interface=wlan0
                            ro.sf.lcd_density=160
                            ro.rk.screenoff_time=-1
                            ro.rk.def_brightness=200
                            ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
                            ro.rk.install_non_market_apps=false
                            ro.default.size=130
                            persist.sys.timezone=Asia/Shanghai
                            ro.product.usbfactory=rockchip_usb
                            wifi.supplicant_scan_interval=15
                            ro.opengles.version=131072
                            testing.mediascanner.skiplist=/mnt/sdcard/Android/
                            ro.factory.tool=0
                            rild.libargs=-d_/dev/ttyUSB1
                            ril.pppchannel=/dev/ttyUSB2
                            rild.libpath=/system/lib/libril-rk29-dataonly.so
                            ril.function.dataonly=1
                            ro.product.version=1.0.0
                            ro.product.ota.host=www.rockchip.com:2300
                            ro.kernel.android.checkjni=1
                            dalvik.vm.dexopt-flags=m=y
                            net.bt.name=Android
                            dalvik.vm.stack-trace-file=/data/anr/traces.txt
                              Re: [RELEASE] MK802 III firmware 31 Oct 2012
                              How to update this through rktools? Its not the same as you update finless rom. The update. Zip has different files.
                              Verstuurd van mijn GT-P6210 met Tapatalk
