So flash tool won't recognise cube talk 9x u65gt
I've the drivers installed and scatter menu loaded and the right boxes ticked but when I click download it isn't showing in the bottom right of the spflash tool so the red bar never starts. I've tried various ways of connecting then turning off, plugging it in after I turn it off and whatever I can think of. USB debugging is on and still no luck. Be grateful of the help at this stage I'm trying to get sixaxis to work for epsxe PlayStation emulatorTags: None
my cube 7x ug51 flashes this way ...
for a first time flash
unplug any usb devices
power off the tab ...
plug in the usb cable with the tab still off ..
windows 7 32 bit should load a "preloader" driver
after driver installed then disconnect the tab ..
setup the flash tool as you did ..
load the scatter file
clik the download
then just plug in the tab ..
sometimes it takes awhile to start but it eventually starts ..
I never have to turn on the tab till it is done flashing ..
clik the download
There are currently 2100 users online. 2 members and 2098 guests.
