I bought an MK809 III and after installing it I get, with
the stock ROM very bad WiFi performance.
After opening it I saw it was an RT3188T with the realtek 8732 WiFi chip.
The stick doesn't have an external antenna but it also doesn't have a wire soldered to the PCB. Is this normal?
Is there anything I can do to improve the WiFi throughput.
Change firmware?
Thank you all.
