No Dobly Digital 5.1 sound to amplifier
    Hello, my Beelink R89 does not give sound 5.1 Dobly digital to the amplifier, is connected by optical cable to the amplifier and HDMI to TV.
    In Sound definitions are spdif passtrought, gives DTS sound but not give sound AC3 (Dobly digital).
    The amplifier points 5.1 Dobly digital but not deliver any sound, already tried almost all custom roms but always with the same problem.
    My amplifier/reciever is Sony
    Someone has the same problem or anyone know the solution?
    Thank you
    Thank you
    Have you tested other AC3 videos?
    Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
      Yes I've tried with many AC3 movies
      thanks
        Have you tried selecting transcoding on?
          where I select that?
            In sound settings, in Xbmc, make sure expert is enabled
              With transcoding on dont give me any sound in reciever just a horrible noise in tv...
                Have you set your sound settings up in android sound setting, not Xbmc ?
                  Yes I've set to spdif passthrough, and no sound of any ac3 movie, just DTS...
                    What model is your Sony?
                    Can is receive ac3 through optical?
                      It's Sony str-DB930, yes he can receive ac3, I have one Wdtv mediaplayer and give AC3 sound in the same movies
                        We should fix it in the next ROM about the Spdif passthrough.
                          Thank you
                          brother ,with spdif passthrough set up in android and using optical cable , flash with 110k or finless 1.2 and install mx player 1.7.34 with H/W decoding selected.... you'll get dts and dolby from any mkv file.
                            Thanks a lot for help my friends ... I will try that options...
                            Oman, when cames the next ROM... Kodi for me is important with spdif passthrough working with all the
                            splendor ☺
