Changelog:
1. On the basis of the test changed Power_Profile.
2. Implemented Test menu in the Settings \ Developers.
3. Light theme, similar to MIUI in orange tones.
4. White customizable gestures.
6. On the USB connection now button instead of doing Tap on the picture.
7. Instead of stock equalizer implemented ViperFX.
Installation Instructions:
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
