CMX Mx box red led wont accept factory file
I got a cmx box which I bricked by loading OpenELEC-Amlogic.MX2.arm-4.97.1.zipwhen I meant to load MX_LINUX-1.00-G18REF_MX2REF-NEWMTD-update.zip.Anyways I can load the MX_LINUX-1.00-G18REF_MX2REF-NEWMTD-update.zip file by jumping the pins and holding reset it loads then reboots to red led.Ive got into recovery a few times I reset numerous times it doesn't help and now I cant load the original files it just errors out.If this box does load by fluke if I set up XBMC it works perfect but I I shut it off or reboot im right back to red led.Any idea what I can try??Tags: None
Originally posted by piperider View PostI got a cmx box which I bricked by loading OpenELEC-Amlogic.MX2.arm-4.97.1.zipwhen I meant to load MX_LINUX-1.00-G18REF_MX2REF-NEWMTD-update.zip.Anyways I can load the MX_LINUX-1.00-G18REF_MX2REF-NEWMTD-update.zip file by jumping the pins and holding reset it loads then reboots to red led.Ive got into recovery a few times I reset numerous times it doesn't help and now I cant load the original files it just errors out.If this box does load by fluke if I set up XBMC it works perfect but I I shut it off or reboot im right back to red led.Any idea what I can try??
If it is a signature verification or an error about wrong date or device, then you need to use a older recovery.img on SDcard.
Give me a link to your stock ROM. The assertion script needs to be removed.
Originally posted by Finless View PostGive me a link to your stock ROM. The assertion script needs to be removed.
BobThis is the stock firmware for the following device: http://www.geekbuying.com/item/CMX-AML8726-MX-Android-4-2-Dual-Core-Mini-TV-Box-HDMI-HDD-Player-1G-8G-Built-in-XBMC-1080P-RJ45-AV-Port-with-IR-Remote-Control—Black-330173.html Firmware Download LINK CLICK HERE just click ” 下载“ button to download file, sorry, i havne’t got time to upload to other place, please bear for the slow download link,but it be downloaded. How to update the firmware? Before you begin you will need […]
or the newest firmware here
Hi, glad to share CMX TV box latest firmware, please check below information: Download link: CMX TV box Latest Firmware Flash method: 1, UnZip the “CMX AML8726-MX Box-174073-20140927” file, and copy the files inside to a SD card’s root directory. 2, Connect CMX to a screen with HDMI cable, press the recover button and then power […]
Thanks a million ive been lost with this
You can try this and hopefully it will work from recovery. I removed any device ID check.
If it doesn't work you may have to make the special unbrick SDcard but you will need to find your uboot.bin somewhere. That's a pretty common board and unbricking has been posted here and other places. Someone probably has the uboot.bin you need.
Try this:
Put all the files in this ZIP on SDcard!
Originally posted by Finless View PostYou can try this and hopefully it will work from recovery. I removed any device ID check.
Try this:
Originally posted by piperider View Postthanks im gonna try right now I did try removing the line before but I think I may have done it wrong hopefully this works will post back
Try this:
I currently use apk multi tool to sign MX2 box firmware and works fine
I don't seem to have any luck doing the same process on the CMX firmware.
this is the steps I do
extract zip
edit files
remove CERT.RSA, CERT.SF, and MANIFEST.MF files from META-INF folder
zip using z-zip
sign apk using apk multi tool.
then i try to flash, it fails at verifying update package, .then gives me installation aborted
Even if i just extract firmware, rezip without changing anything, then resign it will still get it still fails at verifying and i get installation aborted.
I would love any ideas as to why its not working.
thanks
There are currently 2182 users online. 6 members and 2176 guests.
