As the title implies, I have a 2GB MX III and I'm having some issues with external portable drives. Currently I'm on 110K4 but this happened also on 108K4 and now I'm planning to try out Finless' 2.1 but I wanted to know first if someone else had this problem as well.
I have 2 NTFS formatted & portable (aka without external power source) drives, a 1.5GB WD Passport and a 2Gb Toshiba Canvio, and in all the scenarios below I only use one at a time. If I try plugging any of them in the box, they'll constantly make a noise similar to the one when you power them down or unplug them from the USB on the go, and they won't be accessible. I figured that it might have not enough power, so I linked them to an externally powered USB hub and now they're accessible. However, from time to time I can hear a "clank" sound, like the reading arm would be reset, and XBMC crashes. Shortly after it becomes available again.
The next thing that came to mind was that maybe I had more apps accessing the HDD at the same time, such as a SMB server, torrent client, etc, so I turned them all off but the problem still occurs. Any ideas what may lead to this behaviour or how to bypass it?
Cheers
