hello
my nephew lost the original ut2 power supply, therefore I'm looking for a replacement.
as far as I remeber it has a 2 A output, am I right?
is 2.5 mm or 3.5 mm the diameter of the power supply connector?
Moreover, since I have a 3 A power supply could I use it with the ut2 or the 3 A output would damage the ugoos ut2?
hello
Thanks a lot for the replies
Inviato dal mio A0001 utilizzando Tapatalk
3 amp will work fine. Just make sure of the polarity of the plug tip the UT2 needs and what it is on your 3 amp unit. Power supply should have a picture of the tip and indicate what part is positive and what is negative. There might be the same on the UT2 near the power input jack.
FLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
