Cube U9GT2 / Easypad 970 --- Jellybean ROM
Re: Cube U9GT2 / Easypad 970 --- Jellybean ROM
I can help with that.900Supersport
freaktab developer
Hi 900,
that would be fine. In the evening, I have time to add some lines - I assume we will talk about our special friend called init.rc.
With this improvement and a patched(supercharged) services.jar it would be time for version 1.1.
JDfenseLast edited by JDfense; 16 November 2012, 15:16.
No it should just be a change to the parameter file900Supersport
freaktab developer
Voice and Wallpaper Fix
For those you want to install extra wallpapers or want to use there voice for searching is the following fix.
VoiceWallpaperFix
Put the files inside system/apps folder,
restart to cwm,
wipe to factory, cache and dalvic
then reboot ,
ready
JDfense
Jellybean video recording
I found out, that video recording does not work in all JellyBean roms for the easypad/cube. Finless ics work fine.
So far, I have no trace to a fix. I could check, if the camera and gallerygoogle from similar ics does the trick, but it will not be a jellybean solution in case it will work.
Maybe all Jellybean roms for the cube have the same bad source or jellybean googlegallery is not fully compatible to the cube camera.
If someone has an idea, feel free to give a hint.
I don't give up so fast.
JDfenseLast edited by JDfense; 11 December 2012, 21:27.
There are currently 1109 users online. 0 members and 1109 guests.
