all is well on that side.
By cons I have a problem, every time I put the box in standby red light,
it sufficeth me to stop my tv and on again to that the TV01 II box comes out of his sleep
Whereas I do not want to use it, how to stop it wakes from sleep when you turn on the tv.
i have this
SAMSUNG UE46B7000 - 117 cm
If I turn on the tv the TV01 II comes out of standby.
and this
LG 55LN575S - 140 cm
and a pc monitor
SAMSUNG S27B750V
If I turn on the pc monitor the TV01 II comes NO out of standby.
This is what I want it to do when I plug my tv, it does not leave of its standby
Hi, here is the new firmware for TV01II.
http://www.mediafire.com/download/ty...3_20141226.rar
or here from me
The password is geekbuying.com.
Here is the method for how to to flash:
1, Open the "RKBatchTool.exe" in the BatchTool file, on the top, you will see a "FW Path", click the button on the right side, and select the "T032_AP6330_public_root_20141224.img" file in firmware file.
2, Connect the box to the computer with USB cable, press the recover button and then power on, remove your hand from the recover button until it connect successfully that shows in "Connected Devices"
3, Click "Upgrate" to start flash.
Here is the link for RKBatchTool.exe:
http://www.mediafire.com/view/njf19tcdu8mlkuv/Rockchip_BatchTool_v1.7.rar
ps: i have rooted it with kingoroot.and i am in good section
