Video issue samples
    Video issue samples
    I start a new thread to collect video issue samples...
    HowTo extract a part off a MKV
    Download 'MKVToolNix'
    => https://www.bunkus.org/videotools/mkvtoolnix/
    ==> https://www.bunkus.org/videotools/mk...downloads.html
    Windows => https://www.bunkus.org/videotools/mk...s.html#windows
    I use the *.7z which means it's the portable version which I don't have to install...
    We need the 'mkvmerge GUI'
    => mmg.exe
    I attach a small HowTo as PDF (it's really quick and easy to extract at part off the original MKV)
    Determine technical and tag data for video and audio at the original MKV
    I prefer to use 'MediaInfo Lite' (Integrate with MS-Windows shell (drag 'n' drop, and Context menu))
    (http://www.majorgeeks.com/files/deta...info_lite.html)
    Example
    I know the scene which is stutters is from 00:01:30 to 00:01:33 but the problem is, that mkvmerge GUI seems to use another time-code than e.g. vlc so I add 5 sec in front of and after
    => 00:01:25-00:01:38
    and the result is ~19 sec instead of 13 sec and the microstutter are at ~ sec 2-6...
    ==> http://www.file-upload.net/download-...c_2-6.mkv.html
    USE Click image for larger version
ID:	439885 to download the file
    Original
    Code:
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 13.4 Mbps
    Encoded date                             : UTC 2012-11-04 07:31:54
    Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
    Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : [email protected]
    Format settings, CABAC                   : Yes
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 40mn
    Nominal bit rate                         : 10.5 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.211
    Writing library                          : x264 core 128 r2216 198a7ea
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.20:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=10500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.10
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : MA / Core
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 1h 40mn
    Bit rate mode                            : Variable
    Bit rate                                 : Unknown / 1 509 Kbps
    Channel count                            : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Compression mode                         : Lossless / Lossy
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Text #1
    Format                                   : PGS
    Muxing mode                              : zlib
    Codec ID                                 : S_HDMV/PGS
    Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
    Title                                    : normal
    Language                                 : German
    Default                                  : Yes
    Forced                                   : No
    Text #2
    Format                                   : VobSub
    Muxing mode                              : zlib
    Codec ID                                 : S_VOBSUB
    Codec ID/Info                            : The same subtitle format used on DVDs
    Title                                    : normal
    Language                                 : German
    Default                                  : No
    Forced                                   : No
    Menu
    00:00:00.000                             : en:00:00:00.000
    00:02:25.687                             : en:00:02:25.687
    00:05:34.876                             : en:00:05:34.876
    00:10:10.360                             : en:00:10:10.360
    00:14:23.946                             : en:00:14:23.946
    00:18:47.752                             : en:00:18:47.752
    00:22:43.028                             : en:00:22:43.028
    00:29:06.078                             : en:00:29:06.078
    00:36:03.078                             : en:00:36:03.078
    00:43:38.324                             : en:00:43:38.324
    00:49:06.861                             : en:00:49:06.861
    00:57:00.751                             : en:00:57:00.751
    01:01:27.684                             : en:01:01:27.684
    01:05:21.626                             : en:01:05:21.626
    01:09:33.669                             : en:01:09:33.669
    01:15:03.290                             : en:01:15:03.290
    01:22:32.948                             : en:01:22:32.948
    01:27:49.723                             : en:01:27:49.723
    01:31:44.958                             : en:01:31:44.958
    01:34:03.805                             : en:01:34:03.805
    RK3288 Devices
    - Overview BOX (LINK !)
    USE at the link(s) to download the file...
    Code:
    Format                                   : Matroska
    Format version                           : Version 2
    File size                                : 9.89 GiB
    Duration                                 : 1h 56mn
    Overall bit rate                         : 12.2 Mbps
    Encoded date                             : UTC 2012-07-15 22:06:11
    Writing application                      : mkvmerge v3.4.0 ('Rapunzel') gebaut am May 15 2010 09:38:20
    Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format                                   : AVC
    Format settings, ReFrames                : 5 frames
    Duration                                 : 1h 56mn
    Bit rate                                 : 8 897 Kbps
    Height                                   : 816 pixels
    Display aspect ratio                     : 2.35:1
    Frame rate                               : 24.000 fps
    Color space                              : YUV
    Bit depth                                : 8 bits
    Bits/(Pixel*Frame)                       : 0.237
    Stream size                              : 7.24 GiB (73%)
    Title                                    : 1080p Pate
    Writing library                          : x264 core 125 r2200 999b753
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.10:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=16 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Audio #1
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 1h 56mn
    Bit rate mode                            : Constant
    Bit rate                                 : 1 509 Kbps
    Bit depth                                : 24 bits
    Compression mode                         : Lossy
    Stream size                              : 1.23 GiB (12%)
    Title                                    : DTS 5.1
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Audio #2
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 1h 56mn
    Bit depth                                : 24 bits
    Title                                    : DTS 5.1
    Language                                 : Norwegian
    Default                                  : No
    Forced                                   : No
    Text #1
    Format                                   : UTF-8
    Codec ID                                 : S_TEXT/UTF8
    Codec ID/Info                            : UTF-8 Plain Text
    Title                                    : Full Subs SRT
    Language                                 : German
    Default                                  : No
    Forced                                   : No
    Text #2
    Format                                   : VobSub
    Muxing mode                              : zlib
    Codec ID                                 : S_VOBSUB
    Title                                    : Full Subs VOBSUB
    Language                                 : German
    Default                                  : No
    Forced                                   : No
    Menu
    00:00:00.000                             : en:Chapter 00
    00:08:37.458                             : en:Chapter 01
    00:18:17.416                             : en:Chapter 02
    00:25:13.416                             : en:Chapter 03
    00:33:15.041                             : en:Chapter 04
    00:37:40.708                             : en:Chapter 05
    00:48:24.708                             : en:Chapter 06
    00:56:47.000                             : en:Chapter 07
    01:04:56.916                             : en:Chapter 08
    01:11:23.916                             : en:Chapter 09
    01:18:29.416                             : en:Chapter 10
    01:25:58.000                             : en:Chapter 11
    01:35:00.666                             : en:Chapter 12
    01:44:01.250                             : en:Chapter 13
    01:49:57.625                             : en:Chapter 14
    01:56:26.000                             : en:Chapter 15
    Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
    Code:
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 20.0 GiB
    Duration                                 : 2h 23mn
    Overall bit rate                         : 20.0 Mbps
    Encoded date                             : UTC 2013-10-24 16:02:54
    Writing application                      : mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
    Video
    Format                                   : AVC
    Duration                                 : 2h 23mn
    Bit rate                                 : 17.9 Mbps
    Height                                   : 800 pixels
    Display aspect ratio                     : 2.40:1
    Color space                              : YUV
    Bit depth                                : 8 bits
    Bits/(Pixel*Frame)                       : 0.485
    Stream size                              : 17.5 GiB (87%)
    Writing library                          : x264 core 133 r2334 a3ac64b
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.20:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=17850 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.10
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio #1
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Codec ID                                 : A_AC3
    Duration                                 : 2h 23mn
    Bit rate                                 : 640 Kbps
    Bit depth                                : 16 bits
    Stream size                              : 655 MiB (3%)
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Audio #2
    Format                                   : DTS
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 2h 23mn
    Bit depth                                : 24 bits
    Stream size                              : 1.51 GiB (8%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Text #1
    Format                                   : PGS
    Muxing mode                              : zlib
    Language                                 : German
    Default                                  : Yes
    Forced                                   : No
    Text #2
    Format                                   : VobSub
    Muxing mode                              : zlib
    Codec ID                                 : S_VOBSUB
    Language                                 : German
    Default                                  : No
    Forced                                   : No
    Text #3
    Format                                   : PGS
    Muxing mode                              : zlib
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Text #4
    Format                                   : VobSub
    Muxing mode                              : zlib
    Codec ID                                 : S_VOBSUB
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    Menu
    00:00:00.000                             : de:00:00:00.000
    00:11:16.968                             : de:00:11:16.968
    00:20:01.450                             : de:00:20:01.450
    00:30:09.474                             : de:00:30:09.474
    00:39:21.609                             : de:00:39:21.609
    00:48:57.643                             : de:00:48:57.643
    00:59:03.415                             : de:00:59:03.415
    01:08:57.884                             : de:01:08:57.884
    01:17:35.109                             : de:01:17:35.109
    01:28:36.186                             : de:01:28:36.186
    01:40:47.792                             : de:01:40:47.792
    01:50:55.858                             : de:01:50:55.858
    02:00:53.580                             : de:02:00:53.580
    02:10:13.556                             : de:02:10:13.556
    02:12:49.920                             : de:02:12:49.920
    RK3288 Devices
      I had a look at MKV 2 & 3 and could not see any stutter or lag using Kodi 14.0 default settings.
      O option showed no skipped or dropped frames.
      Maybe more noticeable when viewing a complete movie for an hour or two.
      Using the so called RKM.img (no longer available) pretty much standard and running ok i find.
      Draco is on 12~14 hours a days streaming either Vids or Music most of the day.
      Cheers
        Yes, you are right, seems to stutter at different time-codes and also seems to depend on how long the parts are...
        BUT I talk about stock rom and stock xbmc (only this helps Tronsmart to fix it) but at governor performance...
        Last but not least I don't often see (micro)stutters... and that's at "out of the box"
        RK3288 Devices
