want to update CS918 to kitkat
    OK,I did a lot of reading lot of info for my box on this site. I now know which box i have - CS918 TN-BX09_V2.1 1335. i want to flash to kit kat using A sd card using the recovery by powering up holding the reset button. Which image file should i use/place on the sd card to do this. trying not to use the PC method.
    Thanks in advance
    I did try to use RKBATCHTOOL but could not get drivers to load.
    No SD-Card-way at rockchip (rk3188) devices...
    Only via PC...
    RK3288 Devices
    - Overview BOX (LINK !)
      Only via PC...
      Thanks, any advice to get the drivers to load in win8?
        Had you tried one of this drivers
        Download Windows drivers & Android tools voor Rockchip RK3188, RK3066, RK2918. Firmware upgrade, CPUset tool, overclocken. Win 8, win 7, win XP, win 2K
        or this one (driver4.1.1)
        http://www.freaktab.com/showthread.php?16490-Beelink-R89-UBOX-ROM-Tools-release&p=219459&viewfull=1#post219459
        EDIT: Because update sometimes doesn't work, first you have to deinstall the older drivers...
        RK3288 Devices
