NEOMODE HELP REQUIRED
    Hi All,
    I am trying to get my MK809 III working with the latest version of NEOMODE 3.1 Anodroid 4.4.2 Custom Rom.
    Would really appreciate some help.
    I have installed using Neomode Rom Flash Tool v1.37, all seems to work fine expect the blue tooth and wifi.
    Following a little research on here, I then realised I probably need to install a D33 custom Kernal.
    My specific MK809 III is:
    CPU: Rockchip RK3188-T
    WIFI: MT5931SA
    BT: MT6622N
    How do have a clue how to update the custom kernel. Also just to check, the kernel I am looking at is via the link below (MT5931*)
    http://www.freaktab.com/showthread.p...All-(well-most!)
    Also is there a way I could have made a backup of the stock ROM before I made changes.
    Originally posted by WeeMan View Post
    Hi All,
    WIFI: MT5931SA
    BT: MT6622N
    Hi there, You have done most of the work your not far away now,,Download the MT5931 from the first post http://www.freaktab.com/showthread.p...All-(well-most
    unzip the downlod to a safe place on your pc where you no where it is, there is 4 kernals in there 1x SD & 1X HD for tv box & 1X SD & 1X HD for tv stick.
    Open Flash Tool v1.37 untick everything except kernal, on the kernal line to the far right is a little box click in that box & locate the kernal you downloaded select the kernal you require
    Put your stick into flash mode the easyest way is to use the reboot app https://play.google.com/store/apps/d...s.reboot&hl=en & select reboot to bootloader (flash mode)
    At the bottom of flash tool it should say "found RKAndroid Loader Rock usb" or something similar ,
    So now all thats left to do is click flash rom it will only take 3 or 4 seconds & your stick will reboot with your new kernel & you wont loose anything on your device your device we stay the same apart from having a new kernel,,, hopefully you will now have working wifi & Bluetooth.
    Oh one more thing WELCOME TO FREAKTAB weeman
      Thank you for the quick reply.
      Is there a way I could make a backup of my current kernel just in case.
        Also how can I get the app on my tv stick when I have no wife?
          If i understand correct you are on neomode's rom ncr31..If thats correct you allready have a backup of the kernal its in neomode's zip./rockdev/image
            Usb stick,memery card or failing that put the stick into flash mode the same way you did when you first flashed neomode's rom
              Yes I am.
              Will the file location be on the TV stick or my pc?
              I am getting into the TV box modding, not done any modding since I had my HTC HD2 years ago.
              Do u know of any good beginners guides on here so I can swat up on the ins and outs of modding box's.
              Neomode has made doing his mod quite easy using his rom loading tool.
                Yes I am.
                Neomode has made doing his mod quite easy using his rim loading tool.
                Your backup kernal your talking about is in the file you downloaded when you flashed neomode's rom so it will be on your pc,,I cant help you with a modding guide theres bount to be a few on hear somewhere
