How to crash Draco meta
    1) use es explorer to copy 6g from USB2 key (port #3) to usb3 key (port #1, otg)
    2) while copying , watch Netflix .
    3) Netflix will crash , you will get a black screen, remote becomes useless
    4) no other choice then unplug power cord !
    This happened with rom 20141219.v1
    There's probably a hardware problem with USB port #3 ( component #8 in setup guide ) that causes a crash with Logitech c920. When I plug that camera to port #2 , that works
    ___
    I just did the same test but this time I plug USB key in port #2, copying while watching Netflix didn't crash Draco.There's certainly a problem with USB port #3, at least on my box.
    Right now , I use that USB port#3 for wireless keyboard !
    what's the usb port 3#? give me some photos?
    Eric
    Looking for developers
      Eric
      Look at the left side of the box, there are 2 USB ports, it's the one on the right .
        This might be software problem!!!
        1) today, I did the same test again as described on page 1, and that crashed as usual.
        2) I flashed back the official tronsmart rom.
        3) I did the same test and that did NOT crash!
        With the official rom, antutu is 52000, with the rom 29141219v1, antutu is 62000, so they speed up something, and that might generate heat that crashed the box under my test .
        Or under 20141219v1 rom, hardware problem is revealed !!! Where's the truth ?
