How to get number pad on Logitech Harmony working with R89 and xbmc keymap (may work with other 3288 boxes?)
    Originally posted by reeso3000 View Post
    Can't say I have used spmc but I am guessing that it accepts custom keyboard.xml files as its a spin off of xbmc with additional tweaks from my understanding. Are you putting it in the correct location for spmc to read it? try the following location or very similar - android/data/com.semperpax.spmc/files/xbmc/userdata/keymaps
    Let me know how you get on.
    I've put it in the correct folder from spmc. (is almost same filestructure as kodi)
    Will check later on how to fix this.
    thx
