Anyone tried the UG007?
    I would like to buy it told me that the best there is, but I have studied a bit An eternity I realized that someone tried it? There are problems?
    I believe 2dark4u has a first run copy. No report or review yet by anyone.
    I think in a few days they will start to pop up with user reviews.
      Maybe you should check this link:
      At present,the mini PC have gone into the people’s heart deeply.People are conquered by their small and easy carrying.Now I show a TV stick to you .Tts name is UG 007.It’s volume is as small as an usb disk.This kind of TV stick have a black one and white one .
      they already have the unboxing review.
        I saw it but they do not see how it works if it has problems, etc.
          I have briefly run one of these, it looks better built than 802, more stable, no sync problems, had troubles starting the bluetooth once.
          Still I didnt test it long enough to give a better advice.
          I hope I will have some time to test it more.
          Same kriss as on FMA
            Kriss, could you check if sixaxis controller works on UG007 ?
            If you don't have any PS3 controller, you can run this app:
            thx a lot for your help
              The test app reports that the stick is compatible with sixaxis controller.
                Great ! Thanks
                I just bought it, looking forward to receive it
                  I have some wi-fi disconnections when using bluetooth... damn, need to check more...
                  MX Player running fine on it with HW decoding.
                  Have tested Dead Trigger, running great on "High", sixaxis paired but i dont know how to use it right, it moves on both sticks need to check help on the software.
                  Wi-fi Drops could be because I use a computer USB port for powering the stick... just wondering.
                    Two years the only problems she found it just bluetooth is on then there disconnections on wifi? How does he run movies at 1080p? Games run better? And these are not related to whether a sign you control it? If you simply ordinary mouse and keyboard?
                      Just have a look at this video about UG007,it has benchmark and bluetooth test.
                      Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
