cube talk 9x u65gt question regarding stock recovery
    I received my device yesterday (16GB, firmware v2.0_20141111). Everything works ok. Before I start experimenting with root and custom roms I decided to play with the stock recovery. So I turned on the device holding power + volume down and the device booted in stock recovery. The selections were in english. I explored the menus for a while and then I turned off the device pressing power button. So far so good.
    The problem is that the second time I tried to enter recovery mode the menus were in chinese and I couldn't understand anything!!! No matter how many times I tried, recovery menus are in chinese and I can only shut down the device by holding power button. Still the device works perfectly ok when I boot normally into android. Any ideas in order to see recovery mode menus in english?
    Thanks in advance for any help.
    Holding power + volume up - stock recovery in english
    holding power + volume down - recovery in chinese.
    I think that was a mistake...try again holding power + volume up and you should be fine.
    Do not forget to backup your nvram before anything, or write your IMEI on paper.
      Originally posted by Edius View Post
      Holding power + volume down - stock recovery in english
      holding power + volume up - recovery in chinese.
      I think that was a mistake...try again holding power + volume down and you should be fine.
      Thanx for the tip. Actually for my device is:
      power + volume up ---> english
      power + volume down ---> chinese
      I managed to start stock recovery in english again!
      thanx
        thanx
        Holding power + volume down - stock recovery in chinese
        holding power + volume up - recovery in english.
        Yes, stock recovery in english is power + volume up...I wrote in a hurry (I corrected previous posts)
