Trouble with my tr42? my Q7V?
    Hi I Just receive my android tv box buy on Amazon.... CS918... In 4.4.2.
    On my big 55' LG screen no problem... The box come with xbmc rooted etc... Hdmi and RCA ok 720 & 1080.... Perfect. wifi and BT are great.... By déduction I have T-R 42 hardware....
    But on my thomson 32 screen 720 & 1080 résolution won't work.... Black screen....
    I can just sélect 480 and 576 with hdmi câble and RCA.... And the vidéo are horrible....
    I have a WDTV live on this screen and that work fine in all résolution.... I take this android box to replace the WDTV in the bedroom.... :-(
    I try the cable with my onda v812 tablet and 720-1080 résolution work fine too.... So its not a cable issue....
    I download the last update for my thomson tv.... Same problem.... For me after all tests its a hardware issue.... Kernel trouble ?
    No informations on the case or the box, So I open the android box....
    I found à Q7V v10 hardware....
    All the day I flash with différents firmware available on site without succes.....
    Help me....
    Thx
    Inside picture :
ID:	439900Click image for larger version
    Nb sorry for my bad english i'm french. Hope my post is clear...
    Envoyé de mon LG-D802 en utilisant Tapatalk
    latest stock firmware
    This is the latest stock firmware for that box...............dunno if it will cure the problem tho.........
    百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
    good luck
    Vec
      Thx Will try this soon
