Beelink R89 Dead
    Beelink R89 Dead
    Hello to all guys .
    Well i am new to the forum so please excuse my ignorance in some cases.
    I ordered a Beelink R89 from Gearbest 1,5 month before. After so many delays the box finally arrived .
    I was full of happiness , i prepare everything correctly and i plug it on my TV. ( Panasonic Plasma Viera ) with the given HDMI cable that was in the box. i press the button, the blue led lights but nothing else happened . No signal on the screen , no sound, nothing at all.
    I think that that can not be possible so i tried to change the hdmi cable with some that i already had and i know that they are working , i tried another hdmi port , i even try another TV ( Samsung LCD ) but still nothing .
    No i am looking at the box , that has the blue led light but does nothing at all.
    The only thing that i haven`t try is another dc adaptor because i do not have anyone at 3A that the original is.
    Do you think that i must try another adapter too?
    Well i tried to update the machine and put it in recovery mode with all the ways that are writen in the forum but no luck .
    Does anyone had any symptoms like that?
    Anyway i would like to avoid the DOA and return the box to China because of the delays .
    Can you please give me any ideas that ii might did not think??
    Thanks a lot !!
    masking mode
    try to search up masking mode within freaktab and you will se a picture wit the r89 pcb and the two holes you need connect with some wire that might work for you.
    http://www.freaktab.com/showthread.p...device-SOLVED-!!!!!!
      Thanks a lot my dear friend .
      I tried every possible combination but my laptop does not recognize at all the box. I have windows 8.1 and i do not know if that is the problem . I will try with windows xp in a different machine and i will report back. I also bought a new dc adapter to try just in case the problem is with power.
      Any other suggestions maybe?
        Well i tried to several computers !
        The one with Windows Xp recognize the box but couldn`t start the android tool . It said config file failed .
        after that the tool loaded in Chinese but force closed after i choose the firmware and press upgrade.
        The computer with Windows 7 behave the same as the one with XP.
        No i came back to my laptop with windows 8.1 .
        I bought earlier a new cable usb to micro usb and my laptop recognized the box immediately.
        I loaded android tool and i saw that it was in mack mode although i did not open it to short the two holes .
        The normal i think is loader mode correct?
        Mine is always at maskmode whatever i do, even if i just connect the otg to my laptop and plug the power.
        I choose the update firmware it starts doing the job but stucks at download idb fail.
        Can someone pinpoint me to the right direction please?
          No, sorry, we had the same problem here (Download IDB Fail)
          and can't find a solution (till post 11 (forget the posts after 11))...
          But you are the first which device is always at maskmode...
          (But I don't know what happened during your tries at different PC systems...)
          RK3288 Devices
          - Overview BOX (LINK !)
            Thanks a lot for your response. Well before i post my thread i read almost everything about these boxes. I have read also the thread that you proposed and i saw that there is no solution about this too.
            In my tries on the other machines the androidtool did not work at all . Pop up while loading " config file failed " , after that loads in chinese and when i press any button it forces close.
            I install last night windows 7 in a netbook that i also have .
            I did the install fine , i install the drivers also , all correct , i hook up the box with the correct method , it recognizes it correctly but still in maskmode . I try to upgrade with androidtool that is working just fine in the new install and the thing stops in DOWNLOAD IDB FAIL again.
            So stuck again .
            I opened a ticket in Gearbest but no one respond to me till now.
              Todays try !!
              Connect the device
              Erase Flash ( just for a change )
              Flashed erased fine
              Push upgrade button
              Download IDB Fail
              I copy the log just in case anyone find it helpfull or know what to read !!!
              15:01:27 875 AndroidTool v2.3.0.0 start run
              15:02:30 070 Layer<5-4> Download Boot Start
              15:02:32 837 Layer<5-4> Download Boot Success
              15:02:32 848 Layer<5-4>:Wait For Maskrom Start
              15:02:34 399 Layer<5-4>:Wait For Maskrom Success
              15:02:34 399 Layer<5-4>:Test Device Start
              15:02:34 415 Layer<5-4>:Test Device Success
              15:02:34 431 Layer<5-4>:Get FlashInfo Start
              15:02:34 446 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:02:34 446 Layer<5-4>:Get FlashInfo Success
              15:02:34 462 Layer<5-4>:Prepare IDB Start
              15:02:34 524 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:02:34 555 Layer<5-4>:Prepare IDB Success
              15:02:34 571 Layer<5-4>:Erase IDB Start
              15:02:34 571 Layer<5-4>:Erase IDB Success
              15:02:34 587 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:02:34 602 Layer<5-4>:Reset Device Start
              15:02:35 612 Layer<5-4>:Reset Device Success
              15:02:35 635 Layer<5-4>:Wait For Maskrom Start
              15:02:36 765 Layer<5-4>:Wait For Maskrom Success
              15:02:36 796 Layer<5-4> Download Boot Start
              15:02:39 227 Layer<5-4> Download Boot Success
              15:02:39 246 Layer<5-4>:Wait For Maskrom Start
              15:02:40 522 Layer<5-4>:Wait For Maskrom Success
              15:02:40 536 Layer<5-4>:Test Device Start
              15:02:40 552 Layer<5-4>:Test Device Success
              15:02:40 568 Layer<5-4>:Get FlashInfo Start
              15:02:40 574 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:02:40 590 Layer<5-4>:Get FlashInfo Success
              15:02:40 653 Layer<5-4>:Erase Flash Start
              15:02:44 239 Layer<5-4>:Erase Flash Success
              15:02:44 239 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:02:44 317 Layer<5-4>:Reset Device Start
              15:02:45 341 Layer<5-4>:Reset Device Success
              15:02:57 368 Layer<5-4> Download Boot Start
              15:02:59 809 Layer<5-4> Download Boot Success
              15:02:59 824 Layer<5-4>:Wait For Maskrom Start
              15:03:01 073 Layer<5-4>:Wait For Maskrom Success
              15:03:01 084 Layer<5-4>:Test Device Start
              15:03:01 118 Layer<5-4>:Test Device Success
              15:03:01 139 Layer<5-4>:Check Chip Start
              15:03:01 152 Layer<5-4>: Check Chip Success
              15:03:01 170 Layer<5-4>:Get FlashInfo Start
              15:03:01 175 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:03:01 181 Layer<5-4>:Get FlashInfo Success
              15:03:01 196 Layer<5-4>:Prepare IDB Start
              15:03:01 196 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:03:01 243 Layer<5-4>:Prepare IDB Success
              15:03:01 259 Layer<5-4> Download IDB Start
              15:03:06 407 Error:RKU_Read-->ReadFile failed,bRet=1,err=0,size=13,read=0
              15:03:11 414 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=8448,write=0
              15:03:11 414 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector failed,RetCode(-3)
              15:03:16 422 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:21 430 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:21 430 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector-->RKU_EraseBlock failed,RetCode(-3)
              15:03:21 445 Error:Layer<5-4> Download IDB Fail
              15:03:26 453 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:31 460 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:31 460 <LAYER 5-4> ERROR:FindIDBlock-->RKU_ReadSector failed,RetCode(-3)
              15:03:36 468 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:41 476 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:41 476 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(5),RetCode(-3)
              15:03:46 483 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:51 491 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:03:51 491 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(6),RetCode(-3)
              15:03:56 498 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:01 506 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:01 506 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(7),RetCode(-3)
              15:04:06 529 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:11 537 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:11 537 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(8),RetCode(-3)
              15:04:16 544 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:21 552 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:04:21 552 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(9),RetCode(-3)
              15:04:21 552 <LAYER 5-4> ERROR:BufferWriteBack failed
              15:06:28 501 Layer<5-4> Download Boot Start
              15:06:28 609 <LAYER 5-4> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(16386),Sended(0),bRet(0),err(31)
              15:06:28 657 <LAYER 5-4> ERROR DownloadBoot-->Boot_VendorRequest471 failed,index(0)
              15:06:28 689 Error:Layer<5-4> Download Boot Fail
              15:06:53 269 AndroidTool v2.3.0.0 start run
              15:07:29 791 Layer<5-4> Download Boot Start
              15:07:32 480 Layer<5-4> Download Boot Success
              15:07:32 563 Layer<5-4>:Wait For Maskrom Start
              15:07:33 725 Layer<5-4>:Wait For Maskrom Success
              15:07:33 865 Layer<5-4>:Test Device Start
              15:07:33 928 Layer<5-4>:Test Device Success
              15:07:33 959 Layer<5-4>:Get FlashInfo Start
              15:07:33 990 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:07:34 053 Layer<5-4>:Get FlashInfo Success
              15:07:34 084 Layer<5-4>:Prepare IDB Start
              15:07:34 115 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:07:34 177 Layer<5-4>:Prepare IDB Success
              15:07:34 209 Layer<5-4>:Erase IDB Start
              15:07:34 271 Layer<5-4>:Erase IDB Success
              15:07:34 302 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:07:34 349 Layer<5-4>:Reset Device Start
              15:07:35 380 Layer<5-4>:Reset Device Success
              15:07:35 443 Layer<5-4>:Wait For Maskrom Start
              15:07:36 222 Layer<5-4>:Wait For Maskrom Success
              15:07:36 253 Layer<5-4> Download Boot Start
              15:07:38 718 Layer<5-4> Download Boot Success
              15:07:38 749 Layer<5-4>:Wait For Maskrom Start
              15:07:39 595 Layer<5-4>:Wait For Maskrom Success
              15:07:39 626 Layer<5-4>:Test Device Start
              15:07:39 673 Layer<5-4>:Test Device Success
              15:07:39 735 Layer<5-4>:Get FlashInfo Start
              15:07:39 766 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:07:39 797 Layer<5-4>:Get FlashInfo Success
              15:07:39 844 Layer<5-4>:Erase Flash Start
              15:07:44 555 Layer<5-4>:Erase Flash Success
              15:07:44 587 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:07:44 649 Layer<5-4>:Reset Device Start
              15:07:45 718 Layer<5-4>:Reset Device Success
              15:08:17 944 Layer<5-4> Download Boot Start
              15:08:20 407 Layer<5-4> Download Boot Success
              15:08:20 438 Layer<5-4>:Wait For Maskrom Start
              15:08:21 712 Layer<5-4>:Wait For Maskrom Success
              15:08:21 743 Layer<5-4>:Test Device Start
              15:08:21 774 Layer<5-4>:Test Device Success
              15:08:21 805 Layer<5-4>:Check Chip Start
              15:08:21 868 Layer<5-4>: Check Chip Success
              15:08:21 899 Layer<5-4>:Get FlashInfo Start
              15:08:21 946 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:08:21 992 Layer<5-4>:Get FlashInfo Success
              15:08:22 039 Layer<5-4>:Prepare IDB Start
              15:08:22 055 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:08:22 102 Layer<5-4>:Prepare IDB Success
              15:08:22 148 Layer<5-4> Download IDB Start
              15:08:27 343 Error:RKU_Read-->ReadFile failed,bRet=1,err=0,size=13,read=0
              15:08:32 398 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=8448,write=0
              15:08:32 413 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector failed,RetCode(-3)
              15:08:37 452 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:08:42 475 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:08:42 506 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector-->RKU_EraseBlock failed,RetCode(-3)
              15:08:42 616 Error:Layer<5-4> Download IDB Fail
              15:08:47 764 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:08:52 834 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:08:52 849 <LAYER 5-4> ERROR:FindIDBlock-->RKU_ReadSector failed,RetCode(-3)
              15:08:57 888 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:02 911 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:02 927 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(5),RetCode(-3)
              15:09:07 966 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:13 004 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:13 020 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(6),RetCode(-3)
              15:09:18 074 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:23 113 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:23 144 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(7),RetCode(-3)
              15:09:28 186 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:33 225 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:33 240 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(8),RetCode(-3)
              15:09:38 260 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:43 284 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:09:43 315 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(9),RetCode(-3)
              15:09:43 330 <LAYER 5-4> ERROR:BufferWriteBack failed
              15:10:10 178 AndroidTool v2.3.0.0 start run
              15:10:16 047 Error:CheckDownloadItem-->Z:\sdc\ouyang\RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0\rockdev\Image-rk3288\misc.img is not existed!
              15:10:19 227 Layer<>: RunProc is ending, ret=0
              15:10:21 349 Error:CheckDownloadItem-->Z:\sdc\ouyang\RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0\kernel\resource.img is not existed!
              15:10:23 445 Layer<>: RunProc is ending, ret=0
              15:10:25 910 Error:CheckDownloadItem-->Z:\sdc\ouyang\RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0\kernel\kernel.img is not existed!
              15:10:27 470 Layer<>: RunProc is ending, ret=0
              15:10:31 058 Error:CheckDownloadItem-->Z:\sdc\ouyang\RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0\rockdev\Image-rk3288\boot.img is not existed!
              15:10:32 658 Layer<>: RunProc is ending, ret=0
              15:10:38 071 Error:CheckDownloadItem-->Z:\sdc\ouyang\RK3288_R-BOX_ANDROID4.4.2-SDK_V1.0.0\rockdev\Image-rk3288\recovery.img is not existed!
              15:10:40 299 Layer<>: RunProc is ending, ret=0
              15:10:44 448 Layer<5-4> Download Boot Start
              15:10:48 620 Layer<5-4> Download Boot Success
              15:10:48 642 Layer<5-4>:Wait For Maskrom Start
              15:10:50 398 Layer<5-4>:Wait For Maskrom Success
              15:10:50 429 Layer<5-4>:Test Device Start
              15:10:50 507 Layer<5-4>:Test Device Success
              15:10:50 585 Layer<5-4>:Check Chip Start
              15:10:50 616 Layer<5-4>: Check Chip Success
              15:10:50 663 Layer<5-4>:Get FlashInfo Start
              15:10:50 694 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:10:50 741 Layer<5-4>:Get FlashInfo Success
              15:10:50 788 Layer<5-4>:Prepare IDB Start
              15:10:50 866 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:10:50 928 Layer<5-4>:Prepare IDB Success
              15:10:50 960 Layer<5-4> Download IDB Start
              15:10:51 849 Layer<5-4> Download IDB Success
              15:10:51 880 Layer<5-4>:Reset Device Start
              15:10:52 918 Layer<5-4>:Reset Device Success
              15:10:52 981 Layer<5-4>:Wait For Loader Start
              15:11:24 087 Error:Layer<5-4>:Wait For Loader Fail
              15:11:24 134 Layer<5-4>: RunProc is ending, ret=0
              15:12:00 346 AndroidTool v2.3.0.0 start run
              15:12:10 969 Layer<5-4> Download Boot Start
              15:12:13 569 Layer<5-4> Download Boot Success
              15:12:13 600 Layer<5-4>:Wait For Maskrom Start
              15:12:15 600 Layer<5-4>:Wait For Maskrom Success
              15:12:15 662 Layer<5-4>:Test Device Start
              15:12:15 694 Layer<5-4>:Test Device Success
              15:12:15 725 Layer<5-4>:Check Chip Start
              15:12:15 772 Layer<5-4>: Check Chip Success
              15:12:15 803 Layer<5-4>:Get FlashInfo Start
              15:12:15 834 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:12:15 881 Layer<5-4>:Get FlashInfo Success
              15:12:15 912 Layer<5-4>:Prepare IDB Start
              15:12:15 990 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:12:16 052 Layer<5-4>:Prepare IDB Success
              15:12:16 099 Layer<5-4> Download IDB Start
              15:12:17 020 Layer<5-4> Download IDB Success
              15:12:17 035 Layer<5-4>:Reset Device Start
              15:12:18 080 Layer<5-4>:Reset Device Success
              15:12:18 112 Layer<5-4>:Wait For Loader Start
              15:12:49 000 Error:Layer<5-4>:Wait For Loader Fail
              15:12:49 062 Layer<5-4>: RunProc is ending, ret=0
              15:18:39 151 AndroidTool v2.3.0.0 start run
              15:19:38 535 Layer<5-4> Download Boot Start
              15:19:41 368 Layer<5-4> Download Boot Success
              15:19:41 454 Layer<5-4>:Wait For Maskrom Start
              15:19:42 979 Layer<5-4>:Wait For Maskrom Success
              15:19:43 089 Layer<5-4>:Test Device Start
              15:19:43 198 Layer<5-4>:Test Device Success
              15:19:43 323 Layer<5-4>:Get FlashInfo Start
              15:19:43 401 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:19:43 494 Layer<5-4>:Get FlashInfo Success
              15:19:43 541 Layer<5-4>:Prepare IDB Start
              15:19:43 619 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:19:43 681 Layer<5-4>:Prepare IDB Success
              15:19:43 744 Layer<5-4>:Erase IDB Start
              15:19:43 791 Layer<5-4>:Erase IDB Success
              15:19:43 822 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:19:43 869 Layer<5-4>:Reset Device Start
              15:19:44 971 Layer<5-4>:Reset Device Success
              15:19:45 025 Layer<5-4>:Wait For Maskrom Start
              15:19:45 963 Layer<5-4>:Wait For Maskrom Success
              15:19:46 025 Layer<5-4> Download Boot Start
              15:19:48 503 Layer<5-4> Download Boot Success
              15:19:48 569 Layer<5-4>:Wait For Maskrom Start
              15:19:49 561 Layer<5-4>:Wait For Maskrom Success
              15:19:49 611 Layer<5-4>:Test Device Start
              15:19:49 655 Layer<5-4>:Test Device Success
              15:19:49 712 Layer<5-4>:Get FlashInfo Start
              15:19:49 778 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:19:49 855 Layer<5-4>:Get FlashInfo Success
              15:19:49 981 Layer<5-4>:Erase Flash Start
              15:19:58 046 Layer<5-4>:Erase Flash Success
              15:19:58 108 <LAYER 5-4> ERROR:BufferWriteBack-->Found IDB
              15:19:58 233 Layer<5-4>:Reset Device Start
              15:20:00 230 Layer<5-4>:Reset Device Success
              15:20:49 963 Layer<5-4> Download Boot Start
              15:20:52 506 Layer<5-4> Download Boot Success
              15:20:52 552 Layer<5-4>:Wait For Maskrom Start
              15:20:55 578 Layer<5-4>:Wait For Maskrom Success
              15:20:55 656 Layer<5-4>:Test Device Start
              15:20:55 781 Layer<5-4>:Test Device Success
              15:20:55 859 Layer<5-4>:Check Chip Start
              15:20:55 939 Layer<5-4>: Check Chip Success
              15:20:56 045 Layer<5-4>:Get FlashInfo Start
              15:20:56 148 <LAYER 5-4> INFO:FlashInfo: 00 80 CE 01 00 04 04 00 28 00 01
              15:20:56 251 Layer<5-4>:Get FlashInfo Success
              15:20:56 330 Layer<5-4>:Prepare IDB Start
              15:20:56 432 <LAYER 5-4> INFO:CS(1) (14800MB) (SAMSUNG)
              15:20:56 515 Layer<5-4>:Prepare IDB Success
              15:20:56 576 Layer<5-4> Download IDB Start
              15:21:01 866 Error:RKU_Read-->ReadFile failed,bRet=1,err=0,size=13,read=0
              15:21:06 921 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=8448,write=0
              15:21:07 202 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector failed,RetCode(-3)
              15:21:12 240 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:17 279 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:19 292 <LAYER 5-4> ERROR:WriteIDBlock-->RKU_WriteSector-->RKU_EraseBlock failed,RetCode(-3)
              15:21:19 338 Error:Layer<5-4> Download IDB Fail
              15:21:24 440 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:29 463 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:29 494 <LAYER 5-4> ERROR:FindIDBlock-->RKU_ReadSector failed,RetCode(-3)
              15:21:34 533 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:39 603 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:39 634 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(5),RetCode(-3)
              15:21:44 931 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:53 336 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:21:53 414 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(6),RetCode(-3)
              15:21:58 515 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:03 585 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:03 679 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(7),RetCode(-3)
              15:22:08 936 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:14 053 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:14 162 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(8),RetCode(-3)
              15:22:19 310 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:26 408 Error:RKU_Write-->WriteFile failed,bRet=1,err=0,size=31,write=0
              15:22:27 812 <LAYER 5-4> ERROR:BufferWriteBack-->RKU_EraseBlock failed,Block(9),RetCode(-3)
              15:22:27 859 <LAYER 5-4> ERROR:BufferWriteBack failed
                A little bit long your log...
                But if I have a look at
                Code:
                and I see all these Error, maybe your eMMC/NAND is bad / broken...(Of cause I'm not sure but I think so)???
                Also I have no idea what I have to think about
                Code:
                RK3288 Devices
                  That was my think too !!!
                  of course i am not sure too but i did all i could do to save it !
                  Gearbest still not respond in my open ticket about the RMA .
                  as i see it i will wait two months for a working tv box !
                  Plus the 45 days that i was waiting for the faulty one to be delivered !
                  ppppfffffffffff
                  Only someone from Beelink could explain as what are these logs !
                  Like the guy from Minix , but i do not think that Beelink are on forums !
                  Anyway bud luck i guess !
                    If they doesn't react maybe you should post there http://www.freaktab.com/forumdisplay...8-Gearbest-com
                    and also PM gearbest
                    RK3288 Devices
                      Thanks a lot my dear freind !!!
                      You are very helpful !!!
                      i just send a pm to them.
                      I hope they look at their PMs !!!!
                        Hello dear,
                        So sorry to hear that! I just sent a PM to you, please kindly check it.
                        Gearbest.com
                        #1
                        Gearbest TV Box & Mini PC Page
                        #2 Flash Deals Flash Deals
                        #3Coupons Coupons, Coupons and More Coupons
                          Originally posted by gearbest View Post
                          Hello dear,
                          Gearbest.com
                          Thanks a lot for your response .
                          I have just answered your PM. please kindly check.
                          Best regards
