Any idea how to make other players based on Amlogic chipsets boot OS from SD?
Boot from SD?
yes it possible
I dont have amlogic device. but amlogic official out
orginal link: http://openlinux.amlogic.com/wiki/in...rom_an_SD_Card Running Android from an SD Card
Page last modified 11:36, 16 Apr 2013 by cary.wu
Instead of running Android from internal storage, you can run Android from SD card.
You will need to prepare the SD card as follow:
$ sudo fdisk /dev/<your sdcard,for example sdd>
Command (m for help): p
Disk /dev/sdd: 1977 MB, 1977614336 bytes
64 heads, 63 sectors/track, 957 cylinders
Units = cylinders of 4032 * 512 = 2064384 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdd1 1 30 60448+ b W95 FAT32
/dev/sdd2 31 957 1868832 83 Linux
Format the partitions using the following commands:
$ sudo mkfs.msdos /dev/sdd1
$ sudo mkfs.ext3 /dev/sdd2
Download a kernel the Android release from here and placed it in the FAT32 partition:
$ sudo mkdir -p /mnt/fat32
$ sudo mount /dev/sdd1 /mnt/fat32
$ sudo cp uImage.android /mnt/fat32
Unpack the Android rootfs tarball prepared earlier onto the EXT2 partition:
$ sudo mkdir -p /mnt/ext3
$ sudo mount /dev/sdd2 /mnt/ext3
$ sudo tar jxfv out/target/product/m1ref/rootfs.tar.bz2 --numeric-owner -C /mnt/ext3
And the final steps:
$ sync
$ sudo umount /mnt/fat32
$ sudo umount /mnt/ext3
Now you can take the SD card and insert into the M1 reference board, at the uboot command line prompt, issue the following command:
# setenv bootcmd 'mmc init;mmcinfo;fatload mmc 0:1 82000000 uImage.android;bootm 82000000;'
# setenv bootargs 'console=ttyS0,115200n8 root=/dev/cardblksd2 rw rootfstype=ext3 init=/init mac=${ethaddr} rootwait'
# saveenv
# boot
But how to generate the 'uImage.android' ?RK3288 Devices
- Overview BOX (LINK !)
There are currently 2532 users online. 1 members and 2531 guests.
