ADVICE NEEDED - Help me choose an Amlogic S802 Tv Box
    Hi there,
    I am in a search for a cheap, yet versatile android TV box. Been looking for a while, and found two models that are the same in terms of basic specifications.
    One is MXIII Amlogic S802 Quad Core 2.0GHz
    Another is M84K Amlogic S802 Quad Core 2.0 GHz
    So, in basic, both have:
    MXIII Amlogic S802 Quad Core 2.0GHz M84K Amlogic S802 Quad Core 2.0 GHz
    • CPU: Amlogic S802 Quad Core up to 2.0GHz (Cortex-A9)
    • GPU: Octa core ARM Mali-450 GPU up to 600MHz
    • OS: Google Android 4.4.2
    • 2G RAM + 8G ROM
    • Built in XBMC, support 4Kx2K@30fps, 1080P@60fps
    • Built-in antenna for WIFI, suppore dual band Wifi 2.4G/5G
    • Support Miracast/DLNA
    • Support original ecology and custom UI
    • CPU: Amlogic S802 Quad core Cortex A9r4 2GHz
    • GPU: Octa-core Mali-450MP GPU @ 600MHz
    • Android 4.4 KitKat OS
    • 2GB RAM + 8GB ROM
    • Support dual band 2.4G/5G WIFI
    • Support bluetooth function
    • Many XBMC patch are pre-installed
    So, basically the same. What I would like to know, is there a significant difference and/or are there any of you that have had positive or negative experiences with these boxes? Which has more stable firmware? I want to do mainly xbmc multimedia streaming, casual games etc, nothing fancy.
    Thank you for your input.
    I would take the MXIII with 2GB RAM so you can use every fw for the round devices...
    RK3288 Devices
    - Overview BOX (LINK !)
      Yeah, at the end i took the MXIII device, got the feeling the firmware is more up to date.
      Could you point me to the best firmware for the device?
