After doing a search on google and here, i see that that others have had the same problem but I can't seem to find a solution. Any advice?
CS968 Issue
CS968 Issue
I've recently installed SPMC on my CS968 box after failing to backup my beyond xmbc before installing a new wizard. SPMC seems to work fine but I keep getting the following error "One or more files failed to play".
After doing a search on google and here, i see that that others have had the same problem but I can't seem to find a solution. Any advice?Tags: None
Originally posted by nguy View PostI've recently installed SPMC on my CS968 box after failing to backup my beyond xmbc before installing a new wizard. SPMC seems to work fine but I keep getting the following error "One or more files failed to play".
There are currently 1943 users online. 2 members and 1941 guests.
