I already knew that it was a 3188 and I suspected it was a t variant despite the 1.6ghz clock speed. So I looked in the thread about all the different 3188 kernels (d33?) and was aware that they come with different wifi chipsets and such, so I looked to see which wifi was loaded in /proc and selected to download the ones with realtek 8723bs support.
I then flashed the HD kernel in rktool 1.7 i believe. Whatever is the latest one before 2 series tool.
Anyway, since then I can't get it to boot. I made the stupid mistake of not backing up the original first.
I popped the thing open and the board says cyx_809III v5_1 20140726.
I have tried NUMEROUS ROMs both custom ones from the site here and stock ones from various chinese and russian sites which are for 809iii with 8723 wifi, or cyx with 8723, any variation of 3188(t) with realtek 8723bs that I can find, both 1080p and 720p. So many different roms and not a single one will go beyond the boot screen. At this point I have tried wiping the whole thing and started installing whole roms and not just kernels, but nothing seems to work!
If it helps this is the specific device http://www.amazon.com/DIAOTEC-antenn.../dp/B00ECBY5VS
Internally it looks almost identical to the 809iii v5 systems.
My customer really wants this device ASAP so any help is GREATLY appreciated!
Cheers,
-SB
